Keggers Posted September 1, 2015 Report Posted September 1, 2015 I just bought a new insert for my table saw. I can't get my 12" blade low enough for the insert to sit flat in the blade opening slot.I'm "thinking" I can change to a 5/8" arbor and use a 10" full kerf blade to start the upward cut on the insert and then switch over to my 12" blade. My thought processes tell me that changing the arbor shouldn't matter as far as blade placement. Then I started thinking that it might. I don't want to screw up this insert - it cost too much. Please help straighten me out. Thanks! Quote
Brendon_t Posted September 1, 2015 Report Posted September 1, 2015 Do you have a smaller blade you can throw on to start the cut? On my 10" saw, I normally bring a 7" circular saw blade up about half way into the zci and the 10" blade will fit. Quote
Keggers Posted September 1, 2015 Author Report Posted September 1, 2015 Hi Brendon,Yes, I could use one of my dado blades that has a 1/8" kerf to get it started. It was the changing the arbor that I couldn't get right in my mind. My thinking is everything should still line up even with changing arbors. Quote
Guest Posted September 1, 2015 Report Posted September 1, 2015 I am surprised your blade won't go low enough. Maybe there is some dust caked on the threaded rod keeping the blade from cranking all the way down. Quote
Keggers Posted September 1, 2015 Author Report Posted September 1, 2015 I looked for that first, Mike and didn't find anything that would cause a problem. Quote
Guest Posted September 1, 2015 Report Posted September 1, 2015 Can you run a test cut with the 5/8" arbor and the 1" (i assume) arbor to be sure the blade is in the same lateral position? Quote
Brendon_t Posted September 1, 2015 Report Posted September 1, 2015 I'm confused, do your 10&12" blades have a different sizes arbor, hence needing to change it? Quote
Keggers Posted September 1, 2015 Author Report Posted September 1, 2015 I'm confused, do your 10&12" blades have a different sizes arbor, hence needing to change it?Yes, the 12' blade takes a 1" arbor and the 10" and small takes a 5/8" arbor. Can you run a test cut with the 5/8" arbor and the 1" (i assume) arbor to be sure the blade is in the same lateral position? I thought you had it sort of solved for me, Mike. I looked again for dust accumulation and though I didn't find one I did find the adjustment that allows the blade to go lower. After messing with this adjustment I found that in order to get the blade low enough it was bottoming out against the dust collection tube located under the blade. I'm done messing with it. I'm going to change the arbor and make the initial cut using a smaller blade to get it started. First time I've ever cussed my Grizzly saw. Talk about a pain in the butt! Quote
Guest Posted September 1, 2015 Report Posted September 1, 2015 Yes, the 12' blade takes a 1" arbor and the 10" and small takes a 5/8" arbor.I thought you had it sort of solved for me, Mike. I looked again for dust accumulation and though I didn't find one I did find the adjustment that allows the blade to go lower. After messing with this adjustment I found that in order to get the blade low enough it was bottoming out against the dust collection tube located under the blade. I'm done messing with it. I'm going to change the arbor and make the initial cut using a smaller blade to get it started. First time I've ever cussed my Grizzly saw. Talk about a pain in the butt!Well you could always lower the ZCI onto the spinning blade :).... then you will really be cussing. How hard is it to change the arbor? Quote
Keggers Posted September 1, 2015 Author Report Posted September 1, 2015 Well you could always lower the ZCI onto the spinning blade :).... then you will really be cussing. How hard is it to change the arbor? The arbor change is simple. I should have done that at the beginning but I was like you and thought the blade should go down far enough. Quote
weithman5 Posted September 1, 2015 Report Posted September 1, 2015 i by no means have tried this, but i have seen where this problem has been solved by taping, fastening the new ZCI to the top of the old insert. start the cut and when you first get part way through stop and approach as normal Quote
Dave Posted September 1, 2015 Report Posted September 1, 2015 My table saw does not go below the bottom of the insert either. Most of the time I just buy the pre-made inserts that are routed on the bottom to allow it to allow for that. Since it sounds like your does not have that just tape it to the old insert and raise the blade enough to get the new insert to sit all of the way down. Quote
Keggers Posted September 1, 2015 Author Report Posted September 1, 2015 Thanks for all the help and advice. I just changed the arbor and put on a smaller full kerf blade to start the opening. I then replaced the arbor and put the 12" blade back on and finished making the cut. Easy peasy! Wish I'd just done that instead of bothering you guys. I have a tendency to over think simple things sometimes.Taping the new insert to the top of the old one would have worked too. Quote
Mzdadoc Posted September 2, 2015 Report Posted September 2, 2015 Bummer you already cut through! I bought the expensive insert but only as a template to make a bunch of my own. Quote
Mark J Posted September 3, 2015 Report Posted September 3, 2015 My table saw does not go below the bottom of the insert either. Most of the time I just buy the pre-made inserts that are routed on the bottom to allow it to allow for that. Since it sounds like your does not have that just tape it to the old insert and raise the blade enough to get the new insert to sit all of the way down. I was just reading a Fine Woodworking article by Tom Begnal where he describes that process in detail with pictures (and how to make your own insert from plywood). It is in: "The Best of Fine Woodworking Tablesaw Jigs, Tips and Techniques". Don't know if it would be available at the library or their web site, but ome might find it worth a look. It is Taunton product No. 017035. Quote
