Are there any owners of this piece of equipment on here? I've read a few good reviews and a lot of bad reviews that were several years old. I would like to get some newer reviews. I understand that it will have its limitations but for the price and space of a single car garage I have to entertain it. Thanks in advance
I have two of them. The first one came in and worked fine for almost an hour. The beds were co-planer and I could joint boards. Then the pulley which spins the cutter head came off a shaft during operation. Belts were tweaked and smoke did fly. That shut me down.
I talked to Jet and they sent me a new one as well as telling me to keep the damaged unit. Very good customer service.
The second machine was not so nice out of the box. The infeed and outfeed tables were not co-planer and there isn't an adjustment that I can see which will help you straighten them out.
I "fixed" the first machine and that is what I've been using since.
So, to me I would say to not buy one of these machines. The limitations are that it isn't adjustable (which is incredibly important) and the beds are too short to joint a board that is more than 4' long with any consistent accuracy. The machine is flimsy in every way and, most important of all, I think you will not have it for long before you are wanting an upgrade.
I have done a ton of research on jointers recently, I don't recall every reading one nice thing about the cheaper combo units. I know I decided against it early on.
ive been in the market for a jointer for some time. i got interested in jointer/planer combos and did quite a bit of research. although i would love a 12" hh combo, i dont have the funds for one, but reviews of the different manufacturers all seemed pretty positive- main complaints being time to switch over. that wasreading on many forums-not just where the machines are sold.
drop to 10" and it seems quality for them really drops and many complaints, many reviews in the last year. the only one i read positive reviews about was the rikon, but that threw it out of my price range.
for the price of the rikon i could get a dewalt 734 and either a cutech 6" jointer, which im not sure about as its brand new on the market, or a used one off cl.
but i have no confidense in the jet 10" combo.
The problem I have heard from combo planer/jointer owners is that setup time is an issue.  For me, that would be a killer. To me, unnecessary set up time is "wasted effort". That's why I own separates - jointer and planer. My work flow with rough lumber is joint, plane, resaw, joint, plane, saw  Sometimes I skip the first joint/plane cycle if the wood is pretty flat and clean to start with. Having to switch between jointing and planing on a combo would drive me nuts. That's why I avoid using a dado blade in the table saw - way too much setup time.
And as to helicals, +100,000  I switched a 15" griz planer to a shelix and would never go back. It does a beautiful job on figured grain and doesn't assault my eardrums. It even does a sweet job on knots. My next planer will have one too. But watch out for that cheapo crop of HSS helicals that seem to be popping up.  Better to save your coins for carbide.
I have a benchtop model helical head 13 inch thickness planner and a 6 inch straight knife jointer. I also have a HH 15 inch thickness planner that only rarely gets use these days because the 13 inch benchtop model is so convenient. Have a look at my workshop review if you want a closer inspection. https://youtu.be/JZZ3FGsqyco
  • Who's Online   1 Member, 0 Anonymous, 56 Guests (See full list)
    26,008
    Bob44
    Bob44
