woodsmoke Posted January 13, 2016 Report Posted January 13, 2016 I plan to carve kitchen spoons, with possibly other styles later. I have some carving knives/chisels, with others on order for hand carving (no hatchet/axe work for me). I am also thinking of using power tools such as Foredam to rough out the pieces. What grit Kutzall burrs work best on hard wood? And is the Foredom a good choice; model? Thanks Quote
Eric. Posted January 13, 2016 Report Posted January 13, 2016 The Kutzall burrs in a die grinder would be good for small things like spoons. You might also look into some solid carbide burrs. Harry has some decent ones for good prices... http://www.harryepstein.com/index.php/tool-type/burrs.html For bigger carving like furniture or sculptures take a look look at Arbortech. http://www.arbortechusa.com/view/woodworking/ Quote
wtnhighlander Posted January 14, 2016 Report Posted January 14, 2016 A 60 grit equivalent bur and disk from Kutzall work well for general shaping. You'll need a gooseneck scraper, or something like a Guinevere sanding system for the hollows of spoon bowls. Quote
shaneymack Posted January 14, 2016 Report Posted January 14, 2016 I have some of these carbide typhoon bits made by foredom for the die grinder. They are pretty sweet http://www.leevalley.com/en/wood/page.aspx?p=69808&cat=1,130,43409 Sent from my SM-N910W8 using Tapatalk Quote
woodsmoke Posted January 14, 2016 Author Report Posted January 14, 2016 Eric, the solid carbide look aggressive . I will work with a cylinder burr for a start and maybe try a solid with more experience. I saw the Arbortect cutters demo'd at the Baltimore show. Very impressive and hungry. My first and second (only ones) were difficult to sand the concaved part. A scorp will be a help. Actually I won a bid on eBay for a hook knife tonight which should make a nice addition to the arsonal. Is the Foredom unit large enough for shaping a Maloof rocker? That may be in the future . Any thoughts on a Wecheer unit? Is it better than a Foredom? thanks Shaneymack for the burr list. Ron Quote
