CraftyLady Posted December 15, 2010 Report Share Posted December 15, 2010 Hello fellow woody's :-D (Woody's = my term for fellow people that enjoy working with wood):-D I wanted to make my husband a mini ferris wheel with pictures on the end where the seats should go. I want it to be able to spin by itself with a flip of a small switch. I've already figured in my head how to construct it but I need help trying to figure out what kind of motor to use for the turning mechanism. I've read you can use a watch battery but I want it to be a smooth continuous turn. Then I read a microwave motor. True enough its small but its not small enough. Do you guys have any ideas? Thanks for your help :-D Quote Link to comment Share on other sites More sharing options...
Beechwood Chip Posted December 15, 2010 Report Share Posted December 15, 2010 How small does it need to be? Maybe use the motor from an electric clock? On the less expensive ones the hands move continuously. Quote Link to comment Share on other sites More sharing options...
CraftyLady Posted December 15, 2010 Author Report Share Posted December 15, 2010 I wanted it to be small enough where it could possibly fit under the base but I didn't want the base to be so big that it took your eye off the main part. Quote Link to comment Share on other sites More sharing options...
osgw380 Posted December 16, 2010 Report Share Posted December 16, 2010 If you live in a large area a hobby store might have what your after. You'll need one that sells robotics for cars, trains or airplanes. Or you can search ebay most of the time they are listed underneath servos. You'll may need to contact the seller to get exactly what you need. I bought some off of ebay that rotate 180 degrees they are about 1" by 1/2" that run off remote. I'm sure you can get that just run off switch and battery though. Quote Link to comment Share on other sites More sharing options...
jet Posted December 17, 2010 Report Share Posted December 17, 2010 ever see those little fans to cool yourself. battery oper, small, easy to wire an on/off toggle switch. enough torque to turn a larger wheel ?? else - visit to Radio Shack. They have goodies like small motors. Best wishes.. Quote Link to comment Share on other sites More sharing options...
Guest Trace Posted December 17, 2010 Report Share Posted December 17, 2010 Go to the local goodwill or similar store, buy a VCR. Remove the motors from it. Most will run for a good while on a very small battery, or a 3 v output charger unit. All of them can be regulated with a small potentiometer from Radio Shack. I built a water mill for under the Christmas tree using this type motor. Quote Link to comment Share on other sites More sharing options...
