Adam Thekruser Kruse Posted February 29, 2016 Report Posted February 29, 2016 I have a Craftsman bench planer...not top of the line, I agree, but not the bottom either. The problem is it is cutting a dome into anything I put through it. I joint one face, and put it through. By the second pass, the dome is so pronounced it is visible. Seems to happen regardless of width of board or position (left, right, center) it goes through. Any thoughts? Already replaced the blades. Thanks in advance for any help. Quote
drzaius Posted February 29, 2016 Report Posted February 29, 2016 Sounds like the jointer needs some tuning. Look on the Wood Whisperer site, I think he's got a pretty good video on tuning a jointer. Basically, you need to get the infeed & outfeed tables coplanar (front to back & side to side) & have the knives set to the level of the outfeed table. Quote
Brendon_t Posted February 29, 2016 Report Posted February 29, 2016 To clarify, we're talking about a thickness planer,correct? 1 Quote
drzaius Posted February 29, 2016 Report Posted February 29, 2016 I assumed he meant jointer. Maybe not. Clarification please. Quote
Miles11we Posted February 29, 2016 Report Posted February 29, 2016 What exactly do you mean by dome? Do you mean any edge is lower than the center of the board? Quote
Adam Thekruser Kruse Posted February 29, 2016 Author Report Posted February 29, 2016 Yes, sir. That's exactly what I mean. 5 hours ago, drzaius said: Sounds like the jointer needs some tuning. Look on the Wood Whisperer site, I think he's got a pretty good video on tuning a jointer. Basically, you need to get the infeed & outfeed tables coplanar (front to back & side to side) & have the knives set to the level of the outfeed table. Thank you for the comment. Unfortunately, I'm talking about my planner. My Joyner runs like a charm. 5 hours ago, Brendon_t said: To clarify, we're talking about a thickness planer,correct? Yes, sir. 5 hours ago, drzaius said: I assumed he meant jointer. Maybe not. Clarification please. Sorry for the confusion, gentlemen. Wow! I feel like I've created more confusion. I was using voice to text, and it's not always very accurate. To clarify, my jointer runs fine. It is my thickness planer that I'm talking about. When I joint one face, and then run the board through my planer, jointed face down, the board comes out with the edges thinner than the middle. I don't mean snipe. It is like the knives are cutting more on the edges than the center, regardless of whether I run the board through the center of the knives, or to one side or the other. Quote
Brendon_t Posted February 29, 2016 Report Posted February 29, 2016 Ok now that we've got that out of the way. You have replaced the blades and were going to assume they are the right blades, installed correctly. Have you confirmed the bed of the planer is flat? Personally, I'm kind of stumped here. I can't figure out how with a flat bed, jointed face, a dome could be created with straight knives. Is there any chance one side is lower than the other, you ran it through one way then the other essentially creating a dome in the center? Quote
Adam Thekruser Kruse Posted February 29, 2016 Author Report Posted February 29, 2016 Thanks for the reply! Yes, the blades are the correct ones. The bed is granite, so I don't think it is that, but I don't have a way to verify. I took all of the sides off to see if there was some sort of adjustment for the blade roller (sorry...don't know what that thing is called...the thing that holds the blades...cutter head maybe?), because my first thought was that one side was low as well. One side had slipped out of square on the infeed roller, but even after I fixed that, it still cuts the exact same dome. Only thing fixing the roller did was help a little with snipe. My only thought is that I bought it used and the last guy only ran boards through on the sides and never through the center. Quote
drzaius Posted February 29, 2016 Report Posted February 29, 2016 If the knives aren't set properly, that is 1 knife is set too high on 1 side of the head & another is set too high on the other side, it could cause what you are describing. That's just a shot in the dark, I can't think of anything else. 1 Quote
Brendon_t Posted March 1, 2016 Report Posted March 1, 2016 Do you own a dial indicator? If so,take the blade guard off, set the indicator and measure the protrusion of each blade on each side. If no indicator, you can use a piece of a really hard wood like hard maple, say 1x1" joint, cut on ts. Set it under the head and slowly bring the head down obviously turned off and see when the blades touch. It should be about the same time on each side with both blades. 1 Quote
Coop Posted March 1, 2016 Report Posted March 1, 2016 If you took 3 boards, flatten one side of each on the jointer, then feed one board thru the planer on the left side, one thru the middle and one on the right side, is the high side of the board always in the middle? Would it be possible that op's knife blades on his jointer are not set right and maybe higher on one side, then when he runs the board thru the planer, it cuts on the high side of the board, thus leaving a peak in the middle of the board? 1 Quote
Adam Thekruser Kruse Posted March 1, 2016 Author Report Posted March 1, 2016 1 hour ago, drzaius said: If the knives aren't set properly, that is 1 knife is set too high on 1 side of the head & another is set too high on the other side, it could cause what you are describing. That's just a shot in the dark, I can't think of anything else. Thank you for your reply. I thought that as well. The blades have positive stop holes and the cutter head has corresponding pins. I thought maybe, since this is the first planer I have owned, there was something simple that I just didn't know about. I have been woodworking for quite a while, and this just baffles me. Thanks again for your help! 45 minutes ago, Brendon_t said: Do you own a dial indicator? If so,take the blade guard off, set the indicator and measure the protrusion of each blade on each side. If no indicator, you can use a piece of a really hard wood like hard maple, say 1x1" joint, cut on ts. Set it under the head and slowly bring the head down obviously turned off and see when the blades touch. It should be about the same time on each side with both blades. I do not own one...wish I did. I will make a jig this weekend and give it a shot. Thank you for the idea! 7 minutes ago, K Cooper said: If you took 3 boards, flatten one side of each on the jointer, then feed one board thru the planer on the left side, one thru the middle and one on the right side, is the high side of the board always in the middle? Would it be possible that op's knife blades on his jointer are not set right and maybe higher on one side, then when he runs the board thru the planer, it cuts on the high side of the board, thus leaving a peak in the middle of the board? That is a great idea! I will do that this weekend and see. It is a 12". I think I will run 3 6" pieces through like you described, then try a 12" piece. I will post my result after I do. Thanks again! Quote
Coop Posted March 1, 2016 Report Posted March 1, 2016 12 minutes ago, Adam Thekruser Kruse said: Thank you for your reply. I thought that as well. The blades have positive stop holes and the cutter head has corresponding pins. I thought maybe, since this is the first planer I have owned, there was something simple that I just didn't know about. I have been woodworking for quite a while, and this just baffles me. Thanks again for your help! I do not own one...wish I did. I will make a jig this weekend and give it a shot. Thank you for the idea! That is a great idea! I will do that this weekend and see. It is a 12". I think I will run 3 6" pieces through like you described, then try a 12" piece. I will post my result after I do. Thanks again! Or take the board that has the crown and run it thru the planer a couple of more times, crown side up, since it's trash anyway, and see if the crown remains. 1 Quote
Adam Thekruser Kruse Posted March 1, 2016 Author Report Posted March 1, 2016 38 minutes ago, K Cooper said: If you took 3 boards, flatten one side of each on the jointer, then feed one board thru the planer on the left side, one thru the middle and one on the right side, is the high side of the board always in the middle? Would it be possible that op's knife blades on his jointer are not set right and maybe higher on one side, then when he runs the board thru the planer, it cuts on the high side of the board, thus leaving a peak in the middle of the board? I just reread this. You make a good point. I will also double check my jointer knife heights this weekend. That would produce the result you are talking about. Never crossed my mind. Hit something in a board on my jointer a while back and have been meaning to offset the blades anyway. I had just slid the backplate over to not use the knicked section as a temporary fix and forgot about it. Gives me a reason to break it all down and retune everything. Quote
drzaius Posted March 1, 2016 Report Posted March 1, 2016 Dial indicators are pretty cheap & nice to have. Quote
