Rex Edgar Posted July 12, 2016 Report Posted July 12, 2016 What are the experiences with resawing rough timber as far as the blades for the bandsaw? When I purchased my bandsaw a few years back, I got a selection of different blades. The 3/4" blade I selected seems to drag through logs and I am looking to get a quality blade and use it only for planking logs. What's the experience of the bandsaw owners? Quote
Brendon_t Posted July 12, 2016 Report Posted July 12, 2016 My experience is that anything with bark on it can quickly take the edge off of a standard blade. That's why many band mills have a forward circular blade that cut where the kerf is called a debarker. With that said, heat building up during wide cuts like planking logs also deteriorates standard blades.I would say go one of two ways, either a cheap set of blades you know are pretty much disposable or a carbide tipped blade that can be re sharpened multiple times. Quote
wtnhighlander Posted July 12, 2016 Report Posted July 12, 2016 Deep gullets and low TPI seem to be critical for thick cuts like resawing. Quote
Chestnut Posted July 12, 2016 Report Posted July 12, 2016 I have a a resaw king and it works great for cutting wide plants but I'd never use it on a log. I bought some cheap amazon blades for that and have cut a lot of logs with them and it still flys through the wood. I'm up over a few hundred LF of logs cut and it's still doing well. Personally I'd also go disposable just in case you hit something metal. With rough timber you never know. Quote
Ryan Grondin Posted August 2, 2016 Report Posted August 2, 2016 I always use a resaw king, it's a carbide tipped blade. Epic results. Quote
