damaged oil base top coat, cleaning?
i have a small cherry end table with a high build of water lox gloss finish that has been mistreated for a few years. it appears to have partial pieces of candy wrapper coating embedded in it the ink part of the wrapper for color seams to be left in the finish after some waited to long to clean them up and the sun may have baked it in..  any suggestions on how to rejuvenate the finish?  thinner and super fine pad? thanks in advance for any tips.
thanks for the short answer, never saw one of those. was thinking a more subtle approach might be warranted. but i do have some 100 grit.:)
I've not used waterlox, but you could try using its solvent before resorting to sandpaper.  I know it works with shellac and lacquer.  Worst case scenario it doesn't work and you sand it off anyway.
A solvent probably won't be much help with Waterlox, but if I was going to try something it would be "Howard's Restor A Finish " . I have seen it at Lowe's.
thanks guys
i havnt used water lox in a long time, so humor me here a bit wdwerker, must be after it hardens it is like a conversion varnish?
It's a type of oil/varnish mixture. It cures & hardens. Howard's slightly dissolves the surface layer so you might be able to get the ink from the wrapper out.
