Wood movement over a heater.
I need to build a new bookcase for my new apartment. It needs to go in the living room. Annoyingly there's a baseboard heater running around the walls, which is 3" by 9", including a little space to allow for air flow around the heater.
My question is: Is there anything I have to do to help prevent some of the inevitable wood movement and checking that this is going to cause, or do I have to accept that there's nothing I can do about it?
Can you take a picture of the heater and wall so it's easier to see how the heater is setup and where every thing is in relation to it?
Sent from my SM-G930V using Tapatalk
This is the space where it will end up going into. As you can see the baseboard heaters can't be moved. It won't be going in the corner as I need that space for something else.
I'm wondering if plywood would be a better choice, at least for the vertical supports, and the real wood for the horizontals and edge banding.
Not 100% on this... but my gut says that as long as there is adequate airflow around the piece you'll be fine.
Provided it's properly acclimated to this environment I guess. It's going to be a bit of a tough environment, being Nova Scotia the heaters need to be turned up quite high during winter.
I think it's definitely something that can be done. I would go with a solid wood though. Even though ply is going to be more stable with time and shrinkage won't occur as quickly from the dry heated air. It will probably off gas as it warms up in that close proximity to the heater. My suggestion would be to use a hard wood that will resist shrinkage as much as possible and use it as a heat barrier between your heater and outer finished book case.
It was a very common practice to build wooden enclosures around fin radiators for years but they were often lined with asbestos cloth or transite to prevent heat transfer and possible scorching of the wood.
Obviously asbestos isn't going to be an option. Do you have any other suggestions?
1 minute ago, Llama said:
Raybestos :o
I'm wondering if leather was an option too. Glue it to the end grain where it's most likely to split
Take a bit of inspiration from James Krenov, and build the cas on legs that elevate it away from the heater a bit. If you can attach to the wall, then you won't need rear legs close to the heater. Also, avoid creating an inverted box with the lowest shelf and aprons, as that would trap the rising air and concentrate the heat. I would put a "heat shield" under the bottom shelf. Angle it so as to direct the rising hot air out into the room.
Thin sheets of "hardi-board" or cement board backing commonly found in bathrooms or showers. It shouldn't shrink or crack hardly at all over time and it definitely won't burn.
I knew when I said asbestos I would definitely get some kickback on that one.
Now that's an idea. I hate having to bend down to get to the bottom shelf anyway. So if I provide a 2ft gap under the shelves, it solves the heat issue and my bad back will trouble me less. I was also trying to figure out how to incorporate a charging station into the bottom shelf for the kids (who are 6 and 5), for their tablets.That could be a few inches deep - enough to put the tablet on a ledge, with the cables running through the back. Two birds, one stone!
2 minutes ago, OldSouthWoodCraft said:
I knew when I said asbestos I would definitely get some kickback on that one. But that's just me, Mr. Asbestos.
I'm in Canada. Despite the fact we mine the stuff, it's hard to get hold of it.
Raybestos [emoji33]
Unfortunately this would have been Johns-Mansville for the Transite (trademarked and patented) and someone like Dover Manufacturing for the asbestos cloth. Raybestos and Johns-Mansville were in each other's pockets forever.
  • 1 month later...
If you plan on it only being their for most of its life just, i would just keep the wood pretty close to its desired location and sort od heated for a month or so.
If you keep your place both cooled in the summer and regularly have rhe heat on on the winter its just going to be dry without too much fluctuation (its always nice to have a hydrometer), so just build it while it has a low mc and with it being heated the mc will stay low.
If you still feel uneasy about it, change how you were going to build it, use quarter sawn, add mass where it will help, reduce it where it may help etc.
If i was making something for a customer in that situation, I wouldnt be worried about it at all though.
  • 3 weeks later...
This is what I've come up with in Sketchup so far. Thanks for the suggestion. I'm quite enjoying the design process on this one. Makes a change from square boxes :D
