bleedinblue Posted April 29, 2017 Report Posted April 29, 2017 I have two routers, a 2+ HP Craftsman and a small Makita. The edge guides that came with both are pretty lousy and I probably don't have all of the pieces anyway. Are there any aftermarket options, or am I better off making my own baseplate with a fence? I know Rockler has this, does anyone have experience with it? Quote
Derek_PNW Posted April 29, 2017 Report Posted April 29, 2017 There is this base. Seems like it can do a lot of different tasks. http://www.rockler.com/mpower-combination-router-base-crb7 1 Quote
bleedinblue Posted April 29, 2017 Author Report Posted April 29, 2017 Good grief, I don't know how I missed that. I'll give it a bit to see if anyone has better suggestions, but that's probably exactly what I'm looking for. Thanks! Quote
gee-dub Posted April 29, 2017 Report Posted April 29, 2017 I have the first Rockler base you show but, got it for about $25 before they got so proud of it. As an offset base, its great. I don't use the edge guide all that much but, its workable. The mPower looks pretty trick but, you will have to base the value versus what you do and how often you do it. A big plus is that the router goes on and off quickly; not many shop made plates do this. If you are in the trades or if you find yourself facing many different requirements, frequently; that kind of money for a good base is not out of line at all. I do a lot of different things but, the edge guide requirements are not all that varied; hold the router "this far from the edge" is about as complex as I get. I have some advantage that I have zeroed in on one brand and take care that any additions can use the existing arsenal of jigs and fixtures. With a C-man and a Makita your rod spacing, method of attachment and so forth may not match up at all. I did simply buy some 5/16" rod (close enough to the 8mm on the Milwaukee router base, I notice the mPower comes with 7mm and 8mm) to use for ad-hoc fixtures. You may want to play with that a bit before plunking down your dough. For my Colt, I use the Bosch guide. You practically lose sight of the router in this contraption but, it works pretty slick. Quote
bleedinblue Posted April 29, 2017 Author Report Posted April 29, 2017 As of now, the router in general is my most under-used tool of the big five. Thus far the router, be it in my crappy table or handheld, has been used 98% of the time for edge treatments only. I'm looking to expand on it's usage. I just got a full sized table to replace my deplorable bench top, and that should go a long way toward making the router a more usable tool in my shop. As far as this question and the edge guide issue, I am building the Morris chair this summer. As is, my use of traditional mortise and tenon is few and far between (thanks to the Domino) When I need to cut a mortise or two, I cobble something together and make it work. With the complexity of this chair though, I feel I need to stack the odds in my favor and actually prepare the right tools for the job. So that is to be the primary use of the edge guide/aftermarket base, repeatable, reliable mortising. Quote
MattF Posted May 3, 2017 Report Posted May 3, 2017 On 4/28/2017 at 8:01 PM, Derek_PNW said: There is this base. Seems like it can do a lot of different tasks. http://www.rockler.com/mpower-combination-router-base-crb7 I like this one. Going to need an edge guide for the upcoming roubo build. I have a Ridgid, and they dont make an edge guide. Quote
Vyrolan Posted May 3, 2017 Report Posted May 3, 2017 If you want really high quality ones.... http://www.patwarner.com/index.html The guy makes all kinds of great bases (precision round, offset, etc), edge guides, and a nice mortising jig... They're all precision machined and being clear is great for visibility. Disclaimer: They ain't cheap... Quote
ben_r_ Posted May 4, 2017 Report Posted May 4, 2017 And if youre going to go with Pat's stuff, it sounds like you'd better do it soon, things dont sound good. See reply #7: LINK Quote
Vyrolan Posted May 4, 2017 Report Posted May 4, 2017 4 hours ago, ben_r_ said: And if youre going to go with Pat's stuff, it sounds like you'd better do it soon, things dont sound good. See reply #7: LINK =( Quote
