I have a PM2800 past warranty that unfortunately sat in storage for 4 years (was transferred right after I bought it) and now that I am using it I have concerns on the quality of the tool.  No matter what drill bit I put in the chuck it has a slight wobble in it.  I used a dial indicator to measure run-out at the bottom part of the chuck and it was around 0.002-0.004", which is probably reasonable!  Is it possible the jaws of the chuck are not centering the bit properly?
You should be able to tune it up.  First thing I would do is remove the morse taper and make sure it didn't rust, clean it and re-install.  You can buy a dial gauge, or just make one to check run out and use small mallet or brass hammer to correct.  Here is an old article on drill press tune-ups, it covers most of the stuff you need to do.  http://www.rvplane.com/pdf/drill_press_tune-up.pdf
Just Bob has you heading the right direction.  Don't panic.  Runout on a DP can often be improved simply by re-seating the chuck and / or taper.  The chuck, taper and spindle mating areas should be clean and DRY.  I usually start with mineral spirits till the rags or paper towels come away clean, then use naphtha or alcohol to get the surfaces really clean and dry.  Re-assemble and re-check.  Let us know how it goes.
I have a PM2800 with similar issues.  I don't have wobble with all bits but with some.  It's definitely a problem with the chuck because if I fiddle around with bit installation the problem will come and go with the same bit.  It's so slight that I don't even concern myself with it.  If I were a machinist it would be a different story, but it locates holes with plenty of precision for woodworking.
I have three Powermatics and the 2800 is the weakest one.  Sub-par fit and finish and a lacking design.  I'm generally not thrilled with it.  If I had a do-over I would buy something else, probably that newer Jet unit, whatever the model is.  It gets great reviews and it's quite a bit cheaper.  The new Powermatic that replaced the 2800 is a beast and also gets good reviews...but no thanks at that price.  Don't need all that drill press for woodworking IMO.
If your model has a Morse taper on the Chuck then the easy fix is to hit it with a hammer.
Seriously, that is the solution.
You can easily reseat a Morse taper Chuck by retracting the jaws a tapping the Chuck with a hammer. This causes the taper to seat itself more firmly. Don't wail away on it, just tap it like you are putting in a small finishing nail. If needed to hit harder use a piece of wood between the Chuck and the hammer oriented so you are hitting the endgrain.
Thanks for the input, looks like I am heading in the right direction, I will take the chuck/spindle apart clean and tap back on lightly with the hammer.  Will let you know if it improves.  Eric, I am only disappointed in the DP because I had a King drill press prior to the PM and it performed better.  I do expect more from PM!  I do hope it is as simple as a poor seat between the chuck and the tapered shaft.
3 minutes ago, gee-dub said:
Then I guess its safe to say this now . . . The PM2800 got returned for the issues mentioned above and more.
Yes I am sure that is why they came out with the 2800B, too late now so I hope a few tweaks will reduce the wobble to acceptable levels.  If it doesn't then I may replace the chuck with a Jacobs chuck.  Like I mentioned the runout on the arbor is minimal so the wobble must be in the chuck assembly.
Success, removed the chuck and spindle from DP, removed chuck from spindle, cleaned everything with acetone, put spindle back into DP quill, then put chuck on spindle.  I used a block of wood to seat the chuck with a couple of hits with the dead blow.  Put a good bit in the chuck and set the dial gauge to measure on the smooth part of the drill bit where it exits the chuck.  Turned on drill press and got 0.0005 of runout!  Removed drill bit, re-chucked and got the same result.  That's a massive improvement!  Thanks for your help, feel like I have a good drill press now.  Looks like the problem was a poor seat of the chuck to the spindle.
Guess I should do this too.  Probably won't. LOL
Unless you have a lot of rust on your press you could skip the cleaning and removal and just tap with the hammer, it will reseat just fine.
  • Who's Online   3 Members, 0 Anonymous, 33 Guests (See full list)
    26,008
    Bob44
    Bob44
