Unknown craftsman Posted November 2, 2017 Report Posted November 2, 2017 Since the insert is a knife with a facebevel it's kinda like useing a handplane with a steep angle.The cut is just like a scraping action this requires more downward pressure. With straight knifes there's much less downward pressure and it's mostly passing the wood across the head.It really starts to make sense when your trying to flatin soft thinner woods. Im cannot argue about the cut surface being manageable. That's why I have a planer with a Bryd Head . Aj Quote
Mick S Posted November 2, 2017 Report Posted November 2, 2017 42 minutes ago, Unknown craftsman said: Since the insert is a knife with a facebevel it's kinda like useing a handplane with a steep angle.The cut is just like a scraping action this requires more downward pressure. With straight knifes there's much less downward pressure and it's mostly passing the wood across the head.It really starts to make sense when your trying to flatin soft thinner woods. Im cannot argue about the cut surface being manageable. That's why I have a planer with a Bryd Head . Aj Hmm. Sounds counterintuitive to me. The inserts are skewed relative to the angle of attack, similar to skewing a hand plane to reduce the force needed to push it through. Quote
Chestnut Posted November 2, 2017 Report Posted November 2, 2017 The downward force as in pushing the material into the jointer? I'd argue that the angle of attack is not all that different, you could by no means call a regular joitner head low angle. Quote
Unknown craftsman Posted November 3, 2017 Report Posted November 3, 2017 @Mick S yes that's true and they are slightly rounded at least mine are. I suspect that's very necessary because of the face bevel on the insert. Aj Quote
Dknapp34 Posted November 3, 2017 Report Posted November 3, 2017 @Chestnut Curious how big of a difference in terms of noise there was when you changed to a helical head on your 735? I really like my 735, but I have a basement shop and damn that thing sounds like a plane taking off. Quote
Chestnut Posted November 3, 2017 Report Posted November 3, 2017 28 minutes ago, Dknapp34 said: @Chestnut Curious how big of a difference in terms of noise there was when you changed to a helical head on your 735? I really like my 735, but I have a basement shop and damn that thing sounds like a plane taking off. It was the difference between chasing my girlfriend out of the room above me to her being able to watch tv over the noise. It went from needing to double bag hearing protection to running it with just my 13 db reduction ear plugs. It was significant and appreciated. 1 Quote
