zackapotamus Posted December 18, 2017 Report Posted December 18, 2017 I have a commission to turn a section of an old gym floor into a table top for a client, and I need recommendations for a saw blade for my corded Makita Track Saw that will handle the nails holding the hard maple floor boards to the 2 5/8" plywood sheets. I have an old Craftsman circ saw I could put a more standard demo blade into, but I'm hoping to make the final cuts with the track saw without sacrificing a blade in the process if it's possible. Any ideas? Do the Dewalt framing saws have the durability to make 20' of cuts with possible nails throughout? Thanks for your suggestions! Zack Quote
wdwerker Posted December 18, 2017 Report Posted December 18, 2017 I would get a few 3/8" or 1/2" ball shaped magnets and roll them around over the old flooring. They will stop over each nail. Mark the nail locations and plan your cuts between them. K & J Magnetics has what you want. Disc shaped rare earth magnets can be used too. Maybe try 3 or 4 of them stacked then lay them on their side and roll the cylinder around. You can mark the nail locations on blue tape to avoid marring the finish. Clean cuts in wood will not mix with nails ! Some blades may cut a few nails but the cut quality will be poor and rapidly get worse. Remember when cutting with a circular saw the best results are with the good face down if at all possible. 2 Quote
drzaius Posted December 18, 2017 Report Posted December 18, 2017 Do you have access to a carbide metal cutting saw? They will cut wood as well, although slowly. I'd do as @wdwerker suggested, then use the metal saw for the nails & cut the rest with a circ saw with a demo blade. 1 Quote
Dave H Posted December 18, 2017 Report Posted December 18, 2017 If the shank of the Makita is 5/8" you can use a demo circ saw blade it should make it through numerous nails before it's junk, then just buy another $10.00 blade. I use circ saw blades in my table saw when I'm cutting wood that I suspect may have nails I've had good luck with the cut quality good enough for a glue line joint. Quote
minorhero Posted December 18, 2017 Report Posted December 18, 2017 Flooring Nails tend to be pretty small I suspect you're going to hit some no matter what you try to do to avoid them. I would go to Home Depot buy a cheap saw blade and just expect to lose the $20 blade after you're done. Quote
