Doug Fir Mantel Finishing Problem
I have a situation I hope someone can help with.  I installed a Doug-Fir Mantel, 16 inches above a gas fireplace.  It was finished with MinWax penetrating stain and top coated with 3 coats of water based MinWax Polycrylic.  After drying for 3 months the fireplace was fired up and the mantel started to blister on the underside of the mantel.  The temperature on the underside of the mantel is 160F.  Anyone have a solution?  MinWax states their products are only good for 120F.
Yea, that's an issue with either the fireplace or the location of the mantel.  I installed one on a gas fireplace (in fir too) with a WB finish and it's still holding up very well.  It was more than 16" away tho.
The mantel was installed 2" above the fireplace manufacturer's instructions.  The fireplace is a sealed radiant fireplace, very efficient.
If that mantel is hitting 160 degrees, something is wrong!
In the past I have seen requirements for distance up from firebox and limit on how far out the mantle shelf can come. If you want a deep shelf it has to be higher up.
That efficiency may be biting you. A stanrd wood burning fireplace looses much of its heat up the chimney. Yours seems to be putting all its energy into the room. Is there no fan included with it, to help move the hot air away from the wall & mantel?
