refurbishing old Craftsman bandsaw - need help
Hello all.  I've been lurking and reading here for a couple of months now.  I am very new to woodworking and I'm putting together a shop mostly from garage sale/craigslist items.  I got a 12" Craftsman bandsaw that has been in storage for a number of years.  It runs well but needed some tuning up.  I have put new tires and thrust bearings on it so far.  While aligning the blade I discovered this issue.  the blade rubs against the upper blade guide (not the insert!).  I have a few pictures that hopefully show the issue.  I am not sure what the cause is?  Is the blade guide worn out?  Is the blade guide bar/bracket worn out?
the last one is the lower blade guide as a comparison
any advise from the learned folks on this forum is greatly appreciated!
if there is no way to adjust the guides i would say that its the wrong size bearings that's the problem, and welcome to the forum, I'm sure some others will check in
yeah, I was hoping I would just be able to adjust the guide assy left or right but that doesn't appear possible.  The blade guide (that holds the inserts) when not locked down by the set screw seems very loose inside the slot.  It slides forward and back correctly but also has a lot of play left and right but no way to make an adjustment there.
that is one of my theories for what is wrong.  But what in the world would bend something like that without destroying the rest of the saw?  it's 3/4" steel!  I do see a bar on Ebay for 8 bucks + shipping.  Might just grab that.  I think I'll take the bar off this evening and check it out.
Problem solved!  I took off the bar to check if it was bent. It’s not. But, there was a spring laying inside the area where the bar clamps in. I figured that was probably an important piece. I looked at an exploded diagram for the saw and sure enough it goes there ostensibly to hold the bar tight.  So I reassembled the bar with the spring resting on the tightening screw. I screwed everything back down and it lined up just right!
Don’t ya just love it when things work out? Glad it did bud! Looking forward to seeing projects from your shop.
I'm a real newby at this avocation.  I've tried a couple of end tables with minimal success so far. I was unable to get good square cuts so things weren't lining up well. I think I am going to try some smaller items to work on skills and confidence.  maybe some tissue boxes, bedside docking station, things like that.
I think it's best to start small & simple. It can be very discouraging (and expensive) to screw up a big project because you don't yet have the skills. You'll get there.
  • 26,009 Total Members
  • Joseph b Newest Member ·
