Connie Kort Posted April 15, 2022 Report Share Posted April 15, 2022 Hi I have some pieces that have been previously stained and top coated with oil base product. I want to put another layer of water base top coat on top of this. Is this ok and what prep do 8 need to do Quote Link to comment Share on other sites More sharing options...
BonPacific Posted April 15, 2022 Report Share Posted April 15, 2022 As long as it's completely cured it shouldn't interfere. You may have some adhesion issues, same as any time you use a product that doesn't "burn in" to previous layers. A light scuffing to tooth up the previous top coat may help with adhesion, just be careful not to dig into the stain and risk changing the color. I've finished a few pieces with an oil-varnish blend to start, letting it off-gas for a couple weeks, and then topping it with a water-based poly for protection. Haven't had any reported issues. 1 Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted April 16, 2022 Report Share Posted April 16, 2022 +1^ But if you have any doubt, shellac is widely used as a universal 'primer' between clearcoat layers that may not adhere well directly. 2 Quote Link to comment Share on other sites More sharing options...
