roughsawn Posted September 7, 2022 Report Share Posted September 7, 2022 Do you guys know anyone who repairs (welds) broken bandsaw blades? I know Drew had some problems with a few Resaw Kings a while back. Now I have 2 of them sitting out of commission.. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted September 7, 2022 Report Share Posted September 7, 2022 Maybe try the place you bought it? At work, we used to have a big 4-wheel bandsaw, that had a blade welder built into the side of the frame. Simple function, just a pair of clamps to hold the ends together, and a transformer with manual timer controls (aka, a momentary pushbutton). Instruction plate on the side. Clamp blade into position, hold button approx. 10 seconds to weld, joint glows white and fuses. Allow to cool, then pulse until dull red, and cool again. Repeat this 'annealing pulse' 3 times. Quote Link to comment Share on other sites More sharing options...
Coop Posted September 7, 2022 Report Share Posted September 7, 2022 On 9/6/2022 at 7:19 PM, wtnhighlander said: Maybe try the place you bought it? +1 Quote Link to comment Share on other sites More sharing options...
roughsawn Posted September 9, 2022 Author Report Share Posted September 9, 2022 Just a tool supply store. Take your $ and see how fast they can get you out the door. Hopefully Drew will chime in, with what he did with all those blades that broke on him. By the way...Laguna DOES stand behind their product, if they determine it was defective. Quote Link to comment Share on other sites More sharing options...
Wimayo Posted September 9, 2022 Report Share Posted September 9, 2022 Not what you asked, but it is easy to do yourself with a propane torch and silver brazing materil. I've done it many times. Check out youtube videos on the subject Quote Link to comment Share on other sites More sharing options...
roughsawn Posted September 10, 2022 Author Report Share Posted September 10, 2022 Ok, I will! Sure is worth a try, if it works. Thanks! Quote Link to comment Share on other sites More sharing options...
Wimayo Posted September 11, 2022 Report Share Posted September 11, 2022 On 9/9/2022 at 11:43 PM, roughsawn said: Ok, I will! Sure is worth a try, if it works. Thanks! If you have an old blade, do some practice joints first. Even some strips of scrap about the same thickness would work for this. I've found that 55% silver brazing material works the best. Check ebay. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Chestnut Posted October 26, 2022 Popular Post Report Share Posted October 26, 2022 On 9/8/2022 at 8:20 PM, roughsawn said: Just a tool supply store. Take your $ and see how fast they can get you out the door. Hopefully Drew will chime in, with what he did with all those blades that broke on him. By the way...Laguna DOES stand behind their product, if they determine it was defective. Sorry missed this one. All of mine were determined to be defective and were replaced. Not sure how the blade broke. I did figure out that the snodgrass method of mounting carbide blades is a BIG BIG no no. It puts the strain on the gullet of the blade. This area gets hard and brittle from brazing on the carbide teeth. I've switched to mounting the crown on the middle of band between the gullet and the back edge and haven't broken a blade since. 3 Quote Link to comment Share on other sites More sharing options...
