TomInNC Posted October 10, 2023 Report Share Posted October 10, 2023 I am working on some cabinets, and somehow I managed to glue a piece a trim in a spot where I need to put an applied panel. The trim is glued directly to the cabinet box, which is made out of 3/4 ply. Any suggestions on how to salvage this? Since I will be covering this side of the box with an applied panel, I'm not that concerned with any minor damage from removing the trim. Is this something I should use a multitool for? Quote Link to comment Share on other sites More sharing options...
JohnG Posted October 10, 2023 Report Share Posted October 10, 2023 What glue did you use? Heat and moisture might loosen it enough to peel it off. Quote Link to comment Share on other sites More sharing options...
TomInNC Posted October 10, 2023 Author Report Share Posted October 10, 2023 I used Titebond 3. Quote Link to comment Share on other sites More sharing options...
Tpt life Posted October 10, 2023 Report Share Posted October 10, 2023 If you don’t need the trim, I plane then sand. If it is huge, disregard that comment. Quote Link to comment Share on other sites More sharing options...
curlyoak Posted October 10, 2023 Report Share Posted October 10, 2023 Or hit it with a chisel... Quote Link to comment Share on other sites More sharing options...
Popular Post TomInNC Posted October 10, 2023 Author Popular Post Report Share Posted October 10, 2023 I tried the heat gun for about 10 minutes. The trim piece was 3/4 ply, and I don't think the heat was penetrating enough to soften the glue. In lieu of setting the cabinet on fire, I did bust out a chisel and pry the trim off. There was some minor damage to the outer ply of the carcass, but since I'm putting the applied panel there anyway, that's a trivial fix. Lesson learned: no more trying to do woodworking in between innings of playoff baseball. 4 Quote Link to comment Share on other sites More sharing options...
