wtnhighlander Posted July 28, 2024 Report Posted July 28, 2024 2 hours ago, gee-dub said: I think that half of the reason I take so many pictures and post them is so that I can go back and remember how I did some things . It's hard to say if this^^, or the knowledge we glean from others,is the most valuable aspect of the forum! 2 Quote
Popular Post Mark J Posted July 29, 2024 Popular Post Report Posted July 29, 2024 21 hours ago, gee-dub said: I think that half of the reason I take so many pictures ... is so that I can go back and remember how I did some things . For the same reason, I take frequent photos as I go along, even if I'm not posting. 3 Quote
Popular Post gee-dub Posted July 30, 2024 Author Popular Post Report Posted July 30, 2024 Ever onward . . . More pull blanks. Many of you may recognize a screw holding screwdriver. For tiny hinge screws in tight quarters they are very useful. However, this screw is not so useful. Moving along. 2 1 Quote
Popular Post gee-dub Posted July 31, 2024 Author Popular Post Report Posted July 31, 2024 The lacquer is dry enough to work with. The pulls are ready. I lay a piece of tape about in the middle of the front of the lid. I mark a center-line just for overall guidance. I use a couple of small dowels for the pulls. These help me locate the pull when epoxying and resist lateral force. 12 gauge wire has worked well for me for many years. I place the pull at the visual center. I orient it to where I think it looks good and trace a line around it on the tape. I also mark the back of the pull so I know where the no-drill area is. I recommend some sort of depth stop when drilling these irregular thickness shapes. A commercial product is fine but a piece of scrap with a hole drilled through it will work too. I did not use the large drill / dowel combination shown. They are just to show how you can make a quick and dirty depth stop. I drill the pull and place the "dowels". The sharp end of the cut wires act as dowel centers to mark the tape on the lid face. This gives me mating holes. And it looks like so . . . Here's another one. I will finish setting up the balance of the pulls, apply the epoxy and clamp them in place. While the epoxy initially sets I can start ripping stock for the trays. 4 Quote
fcschoenthal Posted July 31, 2024 Report Posted July 31, 2024 On 7/31/2024 at 12:19 PM, gee-dub said: The pulls are ready. I really like those pulls. And no matter what you say about "between project scrap boxes", I don't buy it. Those don't look like scrap wood and with that many with such detail, they're a project in themselves. 1 Quote
Popular Post gee-dub Posted July 31, 2024 Author Popular Post Report Posted July 31, 2024 On 7/31/2024 at 11:38 AM, fcschoenthal said: I really like those pulls. And no matter what you say about "between project scrap boxes", I don't buy it. Those don't look like scrap wood and with that many with such detail, they're a project in themselves. I had to laugh because I meant for this to be: - A break between larger projects. - A good use of scrap. - a stockpile for surprise gift requests. I think it will be all that but I cannot keep myself from drilling down into the details on these things so they turn into more of a project than a break 3 Quote
wtnhighlander Posted August 1, 2024 Report Posted August 1, 2024 @gee-dub, those look like small continuous / piano hinges. Do you have a preferred make & model that works well? Quote
Popular Post gee-dub Posted August 1, 2024 Author Popular Post Report Posted August 1, 2024 I have used these Lee Valley supplied hinges for many years with good success. I used the 115mm x 9mm for the boxes in this thread. That size was unavailable at one point and I used some smaller ones I had in pairs. They all stop at about 95 degrees, will tolerate a fairly heavy lid (as far as small boxes go) but only come in a bright brass finish. HTH 2 1 Quote
Popular Post gee-dub Posted August 2, 2024 Author Popular Post Report Posted August 2, 2024 I know this is getting a little tedious now but I feel like I need to finish up the thread . I lay everything out in the hopes of getting all the pulls on with one batch of epoxy. The white chunks of high density foam (packing from something once upon a time) is to distribute the spring clamp pressure across the asymmetrical pull face. Like so. I joint and thickness more scrap to use for the trays. Rip the stock to the various widths required. One of the pulls rubbed a bit. This mini scraper comes in really handy for this sort of thing. I sometimes forget how many shop made doo-jobbers I use in my work. The depth gauge gets use on almost every project. The router sled is fairly task specific but does let you route things like these mirrored v-grooves and things like sliding dovetails without a lot of bother. These will make more sense once you see the tray assembled. I cut the tray parts at the tablesaw. I tend to just walk each box through all the steps. This does a couple of things for me. I don't get things mixed up and I can compensate for any slight variations in the boxes. I like this better than making everything a little loose so they all fit wherever; that's just me. Fit them with a shooting board. The tray supports get glued in as appliques. I have used e-6000 adhesive for this for many years with good success. It holds tenaciously and remains a bit flexible so things like wood movement on larger projects are not an issue. I ran out of my usual binding tape which has a bit of spring to it. Painter's tape will have to do. Since the tape is the clamp in this application I just set the tray in place (and reverse it to test) to let the glue set. Once the tray frames are cured I will add bottoms, some shellac and give everything a coat of paste wax. 5 Quote
Popular Post gee-dub Posted August 4, 2024 Author Popular Post Report Posted August 4, 2024 I use the frames as a template for the tray bottoms. They get cut at the tablesaw. A MatchFit sled makes this quick and easy even if things are a tiny bit out of square. I tape off the area that will receive glue and apply the finish. A scrap of ply slightly smaller than the bottom acts as a clamping caul. And we're finally done. The trays match whatever material is used for the tops and pulls. Once the paste wax gasses off I will put them in the bin of "last minute" gifts that I keep in the bottom of the hall closet. 5 Quote
Popular Post gee-dub Posted August 5, 2024 Author Popular Post Report Posted August 5, 2024 Closing note that I forgot to include. If you buff a lot of small or odd shaped items I have two words for you . . . String Buffer. 4 Quote
Von Posted August 6, 2024 Report Posted August 6, 2024 Agreed. They look great. And thank you for documenting. I always learn something (and see a jig I want to build). Quote
gee-dub Posted August 7, 2024 Author Report Posted August 7, 2024 @Von @Mark J - Thanks guys. It is good to give back for all the great tips and info I get from our members. Quote
Ron Swanson Jr. Posted August 7, 2024 Report Posted August 7, 2024 @gee-dub your attention to detail is simply amazing. I learn a lot watching you crank out some "between projects" boxes that it feels like you're doing with one arm tied behind your back. 1 Quote
