Dovetails for Roubo workbench. Standar or houndstooth?
On 10/1/2025 at 10:35 AM, Ron Swanson Jr. said:
So you don't need to go premium, though I'm the first to admit that premium is really nice.
I so wish they wouldn't keep proving that this is the case.  I have a couple of Millers Falls No 4 equivalents.  Before the used hand tool market went nuts I think I paid $35 for them.  I did put Veritas PM-v11 irons in them but they perform as well as planes I paid an order of magnitude more for.  It doesn't have to be a BMW or a Mercedes to be a good car ;).
  • 4 weeks later...
Houndstooth dovetails are mostly decorative, offering little extra strength over standard ones. They require more precision and layout skill but are doable with your Veritas saw and sharp chisels. Practice on scrap first to perfect spacing and clean cuts.
Disagree here.
They nearly double the long grain glue surface area and offer an additional layer of mechanical support.
For the purposes of this post/project, standard DTs are plenty strong - so i wouldn't say that HT are a necessity, but they are stronger than their cousins.
  • 2 months later...
Hello again. I've finally been able to get back to the workbench, but I have a question about how to proceed next. I've made the dovetails on the board, but I still need to make the hole in the end cap. The thickness of my board is bigger than the distance I have to the edge of the nut, so I need to reduce the thickness of the dovetail. I have two options. The first is to give it the maximum thickness allowed until it reaches the nut (29mm); the second is to leave a margin so that the nut has a wall (8.5mm wall, dovetail thickness of 20mm). Which option should I choose? By the way, here is a photo of my work on the dovetail. It's the first one I've ever done. I'm happy with it; everything is perfectly straight, smooth, and square. I only practiced seven straight cuts on a pine board before attempting this.
Note: Images 1a and 1b correspond to the 29 mm thickness example; images 2a and 2b correspond to the 20 mm thickness example.
Those are some dang nice looking tails! Now you need some pins to match :)
RE your question 20 MM appears to be about 7/8" which seems robust enough to me given the mortise and tenon of the bench to the end is really doing the majority of the work.
Thanks for sharing and keep up the nice work!
Agreed, as long as you haven't cut the pins yet, you should be fine with narrowing the tails down to 20mm.
Nice job on your tail board. It's very common to cut a rabbet on the back of the tails.
Check out Frank Strazza on YouTube. He's kind of known f for cutting this joint on benches.
When i did mine his videos were a big help.
  • 26,009 Total Members
  • Joseph b Newest Member ·
