On 9/1/2026 at 6:50 AM, gee-dub said:
12 hours ago, wtnhighlander said:
3" diameter @ 24k rpm = 214.2 MPH
So even dialing back to 12k RPM the bit is still going a hundred miles an hour.
  • 3 weeks later...
Yes, generally the larger the router bit, the slower you want to run it. Small bits can usually be run at higher RPM, while larger diameter cutters need lower speeds because the cutting edge is traveling much faster at the same RPM. As a rough guide, I’d start around 18,000–20,000 RPM for small bits, 16,000–18,000 for medium bits, and around 12,000–16,000 for larger cutters, then adjust based on the manufacturer’s recommendations, the material, and how the cut sounds and feels. I wouldn’t rely on RPM alone though - feed rate and taking lighter passes make a big difference too.
  • Who's Online   1 Member, 0 Anonymous, 56 Guests (See full list)
    26,008
    Bob44
    Bob44
