Mike316 Posted October 14 Report Posted October 14 Hi all, My first post. I'm finishing a walnut table using boiled linseed oil and paste wax. The top is sanded down to 400 grit and I've applied three coats of oil. My first coat of paste wax doesn't seem to be buffing out. It's staying cloudy. The humidity is about 65%. Could this be the problem or maybe 24 hours wasn't long enough for the oil to dry enough? Should I let it sit and try another coat of wax later? Thanks, Mike 2 Quote
Popular Post gee-dub Posted October 14 Popular Post Report Posted October 14 BLO takes about 4 times longer to cure than you will ever expect it to. I had to stand this table in my guest bathroom for about 5 weeks before I could wax it. Since then it has performed very well. Since then I have never "flooded" BLO ever again. I do use it but hit 1:1 with mineral spirits and applied lightly. Usually as an element in a 1:1:1 mix of oil and varnish. BLO is a wonderful material. It penetrates, self levels and cures deep in the wood. The downside is that it takes a long, long, time if it is the only element in your finish mixture. I find a bit of Japan Drier helps. Be sure to read the directions; a little bit goes a long way and too much can lead to a brittle top coat. 5 Quote
Popular Post pkinneb Posted October 14 Popular Post Report Posted October 14 First welcome to the forum! Re your question, I agree with @gee-dub if you didn't wait 6-8 weeks for the BLO to dry Its almost guaranteed to be the issue. 3 Quote
Mike316 Posted October 15 Author Report Posted October 15 Thanks guys, I think this is probably my problem. It seems like the oil is keeping the wax from setting up. I've gone back every few hours today and wiped a little more, but it's not really getting much better. Will it eventually dry? If I keep wiping will I get rid of the contaminated wax or what would be the best way to deal with this? Thanks, Mike 2 Quote
gee-dub Posted October 15 Report Posted October 15 If the wax is petroleum based I would say yes, continued wiping will get you there. Flooding BLO causes a deep penetration and "weeping" (the reappearance of droplets) is normal. You basically go back to the piece several times a day and wipe it down like you changed your mind. Eventually it should cure. Once dry to the touch,wait another week and then try waxing again. Good luck. Quote
pkinneb Posted October 15 Report Posted October 15 Again I agree with @gee-dub. Btw that's a beautiful piece! I really like the detail at the bottom of the aprons. 1 Quote
gee-dub Posted October 15 Report Posted October 15 @pkinneb - Shame on me for not saying so. I get caught up in the technical sometimes. It is indeed a beautiful piece. Well worth the extra time and effort to get to the finish line; no pun intended. 1 Quote
wtnhighlander Posted October 15 Report Posted October 15 @Mike316, welcome to the forum. I can only echo the above advice, as my initial experience with BLO was nearly identical to yours. There is an old 'rule of thumb' for using linseed oil: wipe on a thin coat, once daily for a week, once weekly for a month, and once monthly for a year. I'm not that patient, so I abandoned straight oil as a finish. As for your project, the design is clean & elegant. You executed the build quite well, and your selection of material is exceptional. Very well done, sir! 1 Quote
Von Posted October 15 Report Posted October 15 Welcome to the forum. Great looking table. I put BLO on my workbench (mixed 4-to-1 with mineral spirits) and it's still tacky in spots after weeks, so I echo others on the long curing time. I've never tried to put something over it. 1 Quote
Mark J Posted October 15 Report Posted October 15 Welcome to the forum. That is a nice table. Please let us know how the finish works out. 1 Quote
Popular Post Mike316 Posted October 15 Author Popular Post Report Posted October 15 Thanks guys, I'm really glad that I found this group. It goes to show that I'm never to old to learn. This is a piece that I'm donating to Shaw Nature Reserve, which is part of the Missouri Botanical Garden. A friend had to cut the tree so he had it sawn up and donated some of it to me for this project. I studied wood working and wood science at the University of Missouri Columbia, taught and ran a business building furniture and cabinets for most of my working years. Finishing has always been my shortcoming. I mostly applied lacquers and poly, but more recently have gotten back to oil. So this has been a little humbling, which is always a good thing. I noticed that the legs and rails took the wax well, but I applied a third coat of oil to the top and it was just too wet when I tried to apply the wax. Thank you again and I really do appreciate your expertise, Mike 4 Quote
Popular Post TomBexley Posted October 15 Popular Post Report Posted October 15 At this point the table probably needs less product, not more. Keep wiping off anything that works back to the surface and give the BLO plenty of warm air and time to cure before touching the wax again. One safety thing worth mentioning because a lot of people learn it the scary way: don't wad those oily rags up and throw them in a trash can. Lay them out flat somewhere safe to dry or handle them in a proper metal container. BLO rags can heat themselves enough to start a fire. Beautiful table isn't worth burning the shop down over. 3 Quote
