Project Difficulty
Hi all:
I'm still on the fence about the bench. I'm probably most preoccupied with the level of difficulty and requirement for tools.....i.e. I don't have a band saw or a mortising machine........is this going to be possible with the basic power tools and hand tools? And intermediate.....not sure I've done anything this complex. Comments?
Cynthia, I am also an intermediate woodworker and have not done a project this big but its a doable project with basic tools. From looking at the plans, a table saw, planer, jointer, router and chisels/planes are the critical tools from my perspective but I am sure there are people doing this project with much less than this or even no power tools. I think the challenge in this project is you are working with large pieces of wood making it difficult to set up and execute the cuts but if you take your time and have proper set up, the jointery doesn't seem that complex and for the most part forgiving of errors that can be fixed. I would also say that part of the reason I am jumping into this project is the guidance and learning I will get from the Guild. I am sure as challenges come up the guild will have great ideas about how to address. For me the key is to go slow, measure twice, and work methodically on the project. Given all my other time commitments, it will be a long project but in the end I am going to have a really awesome bench that will be a heirloom to pass on to my children.
I agree with Kevin. I think you can get by with very few tools. Unfortunately some of the absolutely required tools are biggies - the jointer and planer. Unless you want to go neanderthal with hand planes, you will need these two power tools or access to them in another shop.
After that, I think a router would be a big timesaver for installing the tail vise - though not absolutely required. A drill press would be nice for all the 3/4" holes and roughing out the mortises, but a cheap brace and auger could work too.
Also don't overlook clamps for gluing up the top.
Thanks for the support, guys.
Those bow clamps are a great idea....but they really are the equivalent of cauls which aren't hard to make.....I figured i'd need them.
I've gotten past the "do I have enough tools" stage. :) Now I'm at the "do I have enough skills" stage. :D No, I think I can do it. Mine may not look as good as some of yours, but I'll get something done. Aaron, the reason I'm spending so much time on the plans now is because I want to make some modifications and I need to understand them *before* I start cutting.
And honestly, I think you could do without the jointer. Wherever you buy rough lumber, you can always ask them to run it through their machines (for a price) and make it S2S or S4S for that matter. Personally, I think the biggest challenge here will be for the woodworkers who currently have *no* bench. I can't imagine that. I at least have a mammoth ugly bench to work on until I finish this one.
When you use a clamp the force the clamp produces radiates out at a 45 degree angle from the clamp. If you use a flat caul it will do the same so depending on the width you are clamping and the distance between your clamps there may not be any pressure on the joint in some areas. Bowclamps solve this problem by having an arc or 'bow' on the side that is adjacent to the work piece.
I understand Tom, and I agree with you. I assumed that any cauls I used would be planed down each side from the center so they aren't flat.
  • 1 month later...
Cynthia, believing you can do it is half the battle. I'm just feeling my way through myself. I started prior to the build and prior to Aaron's latest V9 Sketch Up. Having Marc layout the sequence will take all the mystery out for you. Dig in and enjoy! You'll be proud of the bench you build for yourself.
(null)
While I have most of the tools, I don't have a powered jointer, but I am going to do this build. I did get an beautiful Lie-Nielsen No. 7 for Christmas that I intend to set up per Schwarz, and an old No.5 Stanley that will also follow Schwarz guidelines. I may as well learn to flatten boards on this project as with any other.
As noted above, it is my skill level I worry about, but the only way to get skilled is to work some wood. I figure if I take my time, practice with poplar for the tough parts (I am using soft maple for the bench), I should end up with something pretty nice.
Jump on in Cynthia!
Some tools, some skill, some knowledge and practice can get you started in rocket science, so why not in woodworking. Just take your time and if you don't feel comfortable with an aspect of the project practice that skill on a scrap of cheap wood.
Lots harder to blow yourself up in woodworking also! :)
This is true...........Although I enjoyed blowing stuff up in high school science. Lets see if we can mix up some finishes and getting some atom reaction.
