Solid Ash Roubo Progress
I want to make it up to see Chris Wong and get a live demo of his Grizzly slider. So far, I'm impressed.
  • Replies 52
  • Views 13.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
Posted Images
ok so its been a long day
i worked on the leg vise today and got that finished man am i pooped
so heres the progression
so this was a 3'x10"x "100" board i cut of a 32" piece
it had a little twist so i had to hand plane it then run it through my planer
post-6323-0-47138600-1338078083_thumb.jp
then i jointed one edge on my tablesaw
post-6323-0-56487600-1338078089_thumb.jp
after that i layed out the vise chop
i really liked what mark said about the chop kinda looking like a plane lever cap so i took it one step further and made it look as close to one as i could
post-6323-0-41326900-1338078218_thumb.jp
post-6323-0-81109000-1338078223_thumb.jp
post-6323-0-09221800-1338078313_thumb.jp
i even got a chance to use my no 20 circular plane =) after i cut the angles out on my bandsawpost-6323-0-57771500-1338078374_thumb.jp
post-6323-0-30689700-1338078324_thumb.jp
post-6323-0-84426400-1338078381_thumb.jp
then it was on to drilling the screw holes and tapping them
post-6323-0-85005400-1338078438_thumb.jp
i reversed the vise screw it gives me more clamping capacity and i like the flush look
post-6323-0-88517700-1338078541_thumb.jp
post-6323-0-40528600-1338078595_thumb.jp
im very happy with how it turned out
post-6323-0-55127500-1338078604_thumb.jp
post-6323-0-49426400-1338078611_thumb.jp
i ll finish it up tomorrow by installing the plastic plate in the legs and the guide rollers
thats all for today guys
by the way i never thought to ask. but is the posting of my project like this appropriate? and is this something you guys want me to keep Blogging like this?
any suggestions?
any suggestions?
I could only hope it's somehow inappropriate just so I can keep drooling over your photos and feel naughty about it! Maybe you need to get a couple showcase showgirls to model your craftsmanship?
Even though I've finished my bench and I am very, very happy with it, I really enjoy seeing how others are coming along. Please keep sharing.
so today i finished the leg vise i made the rollers and installed the black plastic plate the the vise screw rides on and adjusted it all and i also made 30 of the drawbore dowels with the lie nielson dowel plate and let me tell you my hand hurts from doing so much damn hammering i should have just bought some dowels lol.
anyways after that i disassembled the base and took my smoothing plane to it remove all the pencil & machining marks.
so next is to cut the grooves in the rails for the shelf and drill the 4 holes to bolt the top down and make the shelf boards then the sliding deadman then assemble and cut the dog holes.
post-6323-0-75497000-1338162464_thumb.jppost-6323-0-24818900-1338162472_thumb.jppost-6323-0-86303700-1338162481_thumb.jppost-6323-0-46807500-1338162489_thumb.jppost-6323-0-11932600-1338162496_thumb.jp
Ok today i had about 2 hours
so i finished planing all of the base parts down & cut the grooves in the rails for the shelf and drill the 4 holes to bolt the top down
then i test fit the base one last time before i assembled the base with the dowels
post-6323-0-12261900-1338253816_thumb.jp
the wham wham wham driving the pins in
After i used a flush cut saw to cut the pins i went back with a chisel for some reason the endgrain looks better paired with a chisel than cut with a saw to me
post-6323-0-01210200-1338253822_thumb.jp
and the base is done yay!
post-6323-0-90500100-1338253832_thumb.jp
so now back to the top slabs i got mortise out the dog holes in the front slab.
then cut the grove for the sliding deadman.
so i got allot done.
i mounted the slabs and checked all leg tenon shoulders to make sure everything was sitting right.
the leg where the vise is needed a little trimming so i did that.
then i marked a spot on the underside of the slabs to pre drill for the spax screws and drilled them.
then i mounted the 2 slabs and made sure all my gaps were correct.
I closed my vise it was an 1/8th inch higher than the bench top so i wet the endgrain with a wet papertowel & used my LV low angle smoother and and trimmed of the excess
post-6323-0-91335000-1338331880_thumb.jp
post-6323-0-31530200-1338331886_thumb.jp
post-6323-0-81985900-1338331893_thumb.jp
After that i layed out my doghole strip locations
post-6323-0-85418300-1338332059_thumb.jp
Then I made a guide block out of some scrap so i could make sure my dogholes were straight down and went to boring with a 1" auger bit
post-6323-0-34300000-1338332097_thumb.jp
post-6323-0-22675800-1338332107_thumb.jp
post-6323-0-06392700-1338332113_thumb.jp
post-6323-0-06260700-1338332989_thumb.jp
post-6323-0-92409100-1338333510_thumb.jp
post-6323-0-84051100-1338333523_thumb.jp
then i got some hand screw clamps to use as fences a square and my router with an edge guide attachment
and made the doge hole square down to an 1 1/2’ deep
post-6323-0-10490500-1338333552_thumb.jp
post-6323-0-93219100-1338333612_thumb.jp
Then i flipped the front slab over and routed the deadman strip
post-6323-0-75742800-1338333651_thumb.jp
here is everything back together with all the holes drilled in its new spot
post-6323-0-81921100-1338333712_thumb.jp
post-6323-0-91453100-1338333725_thumb.jp
post-6323-0-41961900-1338333732_thumb.jp
thats all for today!
Your bench is coming out great. The ash wood selection is awesome, and the chop is super cool...you could make 2 and sell them as the world's biggest salad tongs :-)
All that's left is the deadman and sliding rail, right?
I really love your chop! Great lines!
So no pictures today but installed the leather on the bench and on the leg vise then I finished cutting the dog holes square and I had clamped a piece of scrap Ipe or "ironwood" under the bench so I was using my mortise chisel as it pushed thought the ash top it would not tear out. And I learned a good lesson. Don't use Ipe as your backing board to prevent tear out its too dam hard and will ruin your chisel edges.
So anyways after that I focused on making my bench dogs. I cut all the blanks and I've made the first one so tommorow I'll trace the rest out based on the first and I'll post some pictures of that process. Then the tail vise insert. Then the dead man and finally the bottom shelf then I'll make one last flattening pass and then some finish if everything goes well ill be finished this weekend.
so today i fininshed the putting leather on the dogs & trimming.
Then i made the dog holder for the tail vise now all thats left is the sliding deadman.
post-6323-0-82002600-1338607360_thumb.jp
post-6323-0-09931600-1338607367_thumb.jp
post-6323-0-85839900-1338607375_thumb.jp
post-6323-0-23882000-1338607399_thumb.jp
post-6323-0-33911900-1338607453_thumb.jp
post-6323-0-39893700-1338607459_thumb.jp
post-6323-0-90271800-1338607466_thumb.jp
sorry about not having more picture of the process but im not as patient now and i forget to stop and take pictures.
ok so i was not happy with the gap spacing on the tail vise dog piece so i made another one no pictures in that
but i did complete the deadman rail. and the deadman
actually 2 deadmen lol.
i was not happy with the first one so i made another and i think its much cooler.
my wife just looked at both and just shrugged and said yeh 2 pieces of wood with holes so?
but hey you cant have everything lol
anyways i milled a big 14 wide 2 1/2 inch thick by 10" piece down to make the new deadman and the shelf boards.
here are pictures of all of that.
post-6323-0-95341900-1338842932_thumb.jppost-6323-0-61574200-1338842946_thumb.jppost-6323-0-91036600-1338842955_thumb.jppost-6323-0-10858400-1338842963_thumb.jppost-6323-0-19425400-1338842974_thumb.jppost-6323-0-15416600-1338842994_thumb.jppost-6323-0-17050400-1338843022_thumb.jp
i finished making the shelves last night.
now just the shelf rails
post-6323-0-11818500-1338897214_thumb.jppost-6323-0-22989700-1338897222_thumb.jppost-6323-0-91323700-1338897227_thumb.jp
