how to fix blade wobble on my ridged r4512
noticed the blade moves just slightly and started noticing it on my cuts the the top is missing more material than the bottom...
how do i fix wobble?
i have a good thin kerf comb. freud blade btw
It could be one of two things the blade is loose or bent, or something is wrong with the spindle either bent or a bad bearing. The easiest test would be try a different blade now to save money use an old blade or use a skill saw blade do some test cuts if your getting the same result start checking the spindle. When the blade is dull sometimes the heat that builds up causes the blade to warp are there any burn marks on your cuts, or build up on the blade. Good luck
the blade ist practically new... aside from cutting up about 20 board ft of maple and a couple sheets of birch ply...
i have gotten some burn on the 8/4 maple though... as for build up.. im new but not that i notice
Is this a table saw or miter saw. I'm not familiar with the rigid numbers. I had blade wobble on my DeWalt miter saw and it turned out to be the washers that sandwich the blade. The Dewalt guy said he doesn't know how or why they bend, but most of the time when you get wobble on a Dewalt, it's the washers. This may be the case with the Rigid as well.
yes tablesaw....
ive seen someone (via internet) that made a jig and mounted a grinding stone to grind the arbor wheel.... i dont feel comfortable with this technique so im open to other suggestions
Buy a $5.00 skillsaw blade put it on the saw, and see if it still wobbles in a test cut or two if it doesn't than you need to pull the trigger on a new tablesaw blade. If it does wobble than you'll need to rethink how to fix this. I'll bet when you were cutting the 8/4 maple you got the blade hot enough to warp. A skill saw blade will work on a table saw as long as you don't take out the dimmond knockout I use a skillsaw blade from time to time on my tablesaw like when you have some material that is dirty or could have hidden nails, and I don't want to take a chance with one of my good blades.
When you say your cuts are missing more material at the top than the bottom. Are saying that it's cutting a slight bevel on the edge or for example that the leading edge is 4" and the trailing edge is 4.125". I'm not an expert by any means, but I have 4512 and had something similar to what you're talking about and it turned out to be a fence alignment issue.
Have you checked everything with a dial indicator? If not that could be a good way to figure this out. I have the A-Line-It kit and really like it, but I'm sure anything similar would work.
Also don't be afraid to contact Ridgid, they had my fence problem fixed so fast I couldn't believe it.
no.... its not a fence problem.... i triple check it before every cut... whats happening is the bottom of the piece (sits on the ts top) comes out correct dimensions but the top ( aimed at the ceiling) is getting too much material cut away... so for instance... the 10" saw blade at the tip is moving left to right instead of staying true inline with the cut.... is this were, say, a 40" blade it would be even more drastic of a difference.... its a strange way of putting it i know, but want to be clear
also... i know this now because in the 1-2 seconds before the blade comes to a complete stop i can see the wobble if i watch closely...
I see what you're saying now, I just wanted to make sure I understood what was going on. Sometimes I think I notice a little wobble when mine is coming to a stop as well, but it hasn't effected any cuts for me and I'm pretty OCD about that type of stuff. I think it may have something to do with the centrifugal force exhibited on the blade, I read something like that somewhere at least. Also I've checked the blade runout and arbor runout with the dial indicator setup mentioned above and its only about .0005" on the most outer part of the blade.
Just a thought, but if the blade is wobbling since its doing so on an circular axis it would do so all the way around since the wobble is either in the blade or the arbor. So in other words it would either that off material in a wavy pattern or probably because of the high speed it would even itself out. Thats how a wobble dado works basically(just on a different plane). If it's cutting a clean bevel are you sure it's not the 90º stop? I know this may seem like simple stuff I'm mentioning and you may have checked it already, but I went through the ringer with my 4512 getting it setup and I would forget something little like that and go back a check and sure enough that was part of it. Anyway I know its a pain I just thought it might help.
i know what you mean splinter..... i did check the 90 stop the first time i noticed this and it was off just slightly.... but ive sinced remedied this and as for the bevel its cutting from the wobble... its actually more of a dovetail.. lol being that is is at a perfect 90* now the wobble is taking more matieral from both sides... so much in fact that the 8/4 material i cut was missing .05 more off the top than the bottom....
I think if I were you at this point I'd call(or email) Ridgid. They responded really quick on my issue and didn't give me any trouble about it either. They just sent me a new part. As others have mentioned you might measure the wobble on another blade, because if they have one question I'm sure that would be it. That way you can tell them up front you've already tried that. Since it sounds like it would almost have to be the arbor I think it will a little more of task then mine was, but I still think they'll take care of you. Hope it works out, keep us posted.
Tonydem, there's a relatively easy way to diagnose this.
Use a dial indicator to check the runout on the blade. Mark the "high spot" on the blade, then rotate it 180° on the arbor. Check it again wih the dial indicator, if the high spot is at the marked spot it's the blade. If the high spot has moved to 180° from the mark, it's runout in the arbor.
  • 5 weeks later...
+1 Joraft.....Dad always said, "look for the simple things first....the problem's usually one of these"....my guess is the blade got hot and warped a little.
The R5412 has a well documented defect. I have one and fortunately mine is defect free. Changing the height of the blade on a defective saw will cause the blade to become out of parallel to the miter slot. You can check for this really easily.
Take your throat plate off.
Clamp a straight edge to the table top. The edge of the straight edge should be directly behind the teeth on the blade (on a flat part as far from the center of the blade as you can get without touching the teeth). Leave a tiny but uniform space between the blade and the straight edge
Loosen the height adjustment knob and adjust the height of the blade. If you have a defective saw, you will notice the blade either jump into the straight edge or pull away from it as soon as you put pressure on that height adjustment wheel. While my R4512 does not have this defect, I have seen it in person. The "jump" is very noticeable and as I mentioned, you barely need to change the height of the blade. Simply applying pressure to the adjustment wheel causes the blade to jump.
If this happens you have a defective table saw. There is nothing you can do to fix this. Contact Home Depot or Ridgid for a replacement
If that doesn't happen, proceed with the runout check Joraft described above. If you do need to adjust the saw for runout, there is a good write-up here. If you have never done this, I would recommend it. My saw was WAY off right out of the box. If you do need to make adjustments, don't forget to realign your rip fence after.
