Help troubleshooting sprayed oil-based enamel issues
Don, the problem may be with the oil based primer. I always use lacqer based sanding sealer under lacquer because the solvent in the lacquer could cause the oil based to reactivate and bubble. Paint a sample board with your primer and when is is dried, wipe it down with a cloth and lacquer thinner. See if the finish is effected at all.
I frequently spray that same black lacquer over the top of Kilz original oil based primer with out issues... The problem seems to be and under estimate of how pigmented lacquers show every imperfection in the surface prep. If you are going to spray lacquer over a primer the primer needs to be applied by spraying then sanded smooth. With that being said the most correct product to use under lacquer is a lacquer primer or surfacer.
Don, I would recommend to let the lacquer dry thoroughly and then sand it smooth then start applying on top of that. Sorry that this project is turning into a nightmare.
Listen to Dustin, he's the MAN! On Christmas Eve I finished a small Cherry box to put the wife's Christmas present in. It wasn't worth setting up my spray rig just to spray it with lacquer, so I called Dustin and ran over to his shop and sprayed it there. Thanks again Dustin!
Best of luck with your project Don, sounds like it's been quite an adventure so far.
I used Zinser oil-based primer, but I think you've got it nailed, Dustin. I can see every divot and low spot on the boards that I sprayed without priming so i figured that I would need to get the primer smoothed before i shot the lacquer. I guess i just didn't get it smooth enough. As for spraying it, that puts us back at the original problem...the primer is far too thick for me to spray with my gear and the instructions say not to thin it. I'll give it a shot at sanding and shooting another coat or two.
If nothing else this project has taught me the right tool for the right job and what finishes work together.
Sometimes the best experience gained is from the most difficult road traveled. It may have been a long way to get there but looks like you were rewarded in the end. Great have this wonderful resource to draw and great results in the end. Looks like next time you'll be the one who will be able to share the advice.
So I beat the finishing beast. I ended up not using lacquer. As I was working on the headboard I came to the realization that because of the properties of pigmented lacquer that Dustin mentioned it was going to take a ton of work and probably money to get the headboard into a condition that black gloss lacquer would look good on and be something that I would be proud to give. Like the folks at Anheuser Busch say, "Know when to say when"...and I hit that point. Decisions that I made in terms of construction and materials selection and prep without knowing exactly what finish I was going to use on the final product ended up stacking the deck against me. I realized that I needed to find a product that was a little more forgiving, and I did.
Rust-Oleum Protective Enamel. $9.48 a quart at Home Depot. It ain't high tech, it ain't glamorous and it will probably earn me a few scoffs...but it worked. As an added bonus the bed will be protected from rust!
So just when I thought I had this thing beat.....
I go out to the shop to put everything together and get it ready to deliver tomorrow.
I learned another valuable lesson - Always dry fit your parts. Before you start finishing.
Somewhere along the line I messed up a measurement or a calculation and mounted the brackets on the headboard where the frame attaches 2" too low. So now I have to decide if I want to cut 2" off the legs at the foot or move the brackets....and screw up that beautiful finish.
Don, remember.....as chief architech, engineer and designer on this project, you are allowed any design change that you deem necessary. It is not a mistake. It is a design change.
Good point, Troy...and we were all set to go with that last night and be done with it when we realized how low it would put the bed and so moving the brackets won out.
Bed finished, delivered and assembled...to a flurry of thank yous and hugs. So in the end all the headache is worth it.
  • 26,009 Total Members
  • Joseph b Newest Member ·
