jahill5 Posted January 24, 2017 Report Share Posted January 24, 2017 Hey Guys, I have a kitchen remodel under way, and I'm trying to match a finish. Of course this is complicated, which is why I'm tossing this out to you guys. I have attached a couple photos of the finish on a buffet sideboard. I am trying to put a finish on some cherry cabinets, and am trying to match the style to the buffet as possible.The existing stain seems to be semi-transparent. I've never had to match something existing before, so any help or suggestions as to what the existing finish may be, will get me started (and will be much appreciated). The color is going to be similar, but not exact. I attached a third photo of the color chip (it's a viking range color). Any ideas on what sort of product to use to achieve that color will also be appreciated. Joshua Quote Link to comment Share on other sites More sharing options...
treeslayer Posted January 24, 2017 Report Share Posted January 24, 2017 looks like a job for dye to me, google Transtint wood dye, Bordeaux, Bright Red and Red Mahogany look close to me. you can use your preferred finish on top, varnish, lacquer ect. and welcome to the forum and let us know how it turns out. be sure to practice on some test pieces first to see how the dye looks on the cherry. Quote Link to comment Share on other sites More sharing options...
Chet Posted January 25, 2017 Report Share Posted January 25, 2017 The one thing I might add to what Dave has said already is that you need to be aware of you clear finish. If you use something like varnish it will yellow your tint a little. If you use a water bourne finish like General Finishes High Performance it won't change your color tint much at all. 1 Quote Link to comment Share on other sites More sharing options...
wdwerker Posted January 25, 2017 Report Share Posted January 25, 2017 Looks like a glaze over paint to me. I also agree with Chet using a water bourne finish over whatever colorant you decide on with protect without adding a amber tint. Quote Link to comment Share on other sites More sharing options...
