jgoeden Posted March 19, 2013 Report Posted March 19, 2013 Guy, first time posting here, tons of reading though.. Ok so I have a Dewalt DW744x (??) construction table saw and I make endgrain cutting boards, so I cut a lot of 8/4 hard wood (sugar maple, cherry, purpleheart). Anyways, after some scary moments on the saw over the last few weeks, it's starting to scare me a lot to even use it. So, I finally broke down and bought a Gripper push block and that's helped me, and the other night I was working for about 6 hours, cutting TONS of wood, no problems, smooth as butter. Here's my problem. I don't have a splitter or riving knife on the saw, so I took off the throat plate to put the riving knife on, and realized it's too tall for my Gripper block to pass over, so I took it off. This is literally the ONLY "adjustment" I've done to the saw since using it 3 days ago (and running wood perfectly). Now it seems if my blade is out of alignment. Is that possible just by messing with the 2 riving knife bolts? My saw bogs down, is burning wood, and wood is getting jumpy and scaring the shit out of me. It's doing this with both the fence and my sled (which is about as perfect of a square as you can get). I make an approximately 8" cut, the blade bogs down, so I shut off the blade and measure, and in 8", we're off about 0.0025" - 0.004", on both the sled and the fence. Do you think my blade is out of alignment just from tinkering with the riving knife? How can I get it aligned? Looking for some advice/encouragement. I'm scared to death something is going to happen, so worried that I'm comtemplating selling all of my tools and stopping woodworking. I'm an RN, so if I go losing fingers or hands, my career is over. I'm finally getting to the point where I'm making good money off of my boards, and business is starting to pick up, and now I can't even make cuts... I know I'm long winded, but I'm just honestly scared of my saw and desperately need any kind of advice or help. With a new baby, and a busy busy career, I don't have 8 hours a day aligning my tools, I need to be cutting wood, not aligning blades all day.... Also, once I get my blade aligned (praying to God that this is "only" the issue here), I'm considereing getting a Biesemeyer or Vega fence to help... Quote
pghmyn Posted March 19, 2013 Report Posted March 19, 2013 I'm no expert, but I have a few ideas that might be able to help you. 1) Unplug your saw, then raise the blade fully and see if you can wobble it with your hand. Check the arbor nut, and check to see if the two riving knife screws are indeed riving knife screws. It could be that one was not, you never know. 2) Check to see that your fence is locking correctly. When you push down the lever, can you move it more than normal? 3) Is the fence in alignment with the blade? Quote
Dave H Posted March 20, 2013 Report Posted March 20, 2013 Also is there wobble in the blade maybe you tweaked the blade removeing the riving knife. Quote
TRBaker Posted March 20, 2013 Report Posted March 20, 2013 J, if you raise your blade all the way up and measure over to your miter gauge slots, from the front and rear of your blade, the measurements should be the same. If they are not, then it is your blade that is out of alignment. There should be four bolts that hold your table and blade in alignment. If you loosen them, you can adjust the alignment. I must add ....It's an extreme pain in the butt, but doable. Quote
Levi Rathje Posted March 20, 2013 Report Posted March 20, 2013 Since the problem started when you put the riving knife on I think you need to look into that make sure it isn't a full kerf riving knife with a thin kerf blade. Also check that it's not bent. Quote
Dlhunter Posted March 20, 2013 Report Posted March 20, 2013 Is your throat plate sitting in the same position? Is it flush to the surface? I'm not sure how the one on your saw is attached but if it screws down you may have cranked it down to tight during the reinstallation. If its lower than the rest of the surface of your table saw and you are ripping stock that could be binding you up. Check it out homie. Quote
jgoeden Posted March 20, 2013 Author Report Posted March 20, 2013 Guys, thanks for the help so far. I know for a fact that it IS and it ISN'T the fence. Yeah, the fence is junk and not well aligned, but this does it too with my perfect 90 cross cut sled which is weird. I'll double check the two knife bolts, but I'm 99.9% sure I got the right ones. I just can't believe this thing popped out of alignment after only messing with the riving knife. Which leads me to this. I think I've convinced myself overnight after I wrote the post to sell the crappy Dewalt construction saw and get a nice Grizzly cabinet saw with a really nice fence. Just drop the money now before I lose a finger or a hand. Any thoughts on this?? Quote
dwacker Posted March 20, 2013 Report Posted March 20, 2013 Checking the fence and miter slot will tell where to go. It may just be the table or trunion moved. Quote
bobcrosley Posted March 20, 2013 Report Posted March 20, 2013 Guys, thanks for the help so far. I know for a fact that it IS and it ISN'T the fence. Yeah, the fence is junk and not well aligned, but this does it too with my perfect 90 cross cut sled which is weird. I'll double check the two knife bolts, but I'm 99.9% sure I got the right ones. I just can't believe this thing popped out of alignment after only messing with the riving knife. Which leads me to this. I think I've convinced myself overnight after I wrote the post to sell the crappy Dewalt construction saw and get a nice Grizzly cabinet saw with a really nice fence. Just drop the money now before I lose a finger or a hand. Any thoughts on this?? I don't think you'll ever regret owning a cabinet saw, so if this is the excuse you're looking for... That being said, I still think you should try to find out what is wrong with your Dewalt and fix it if possible. I know I couldn't feel good selling a tool I thought was unsafe. Plus, if it's working well, you will get top dollar for it selling it used. While some might want to buy a table saw without testing it first, I know I wouldn't. I just bought a used Ridgid contractor saw and I made a test cut before I gave the guy money. Quote
Dlhunter Posted March 20, 2013 Report Posted March 20, 2013 Did you remove the blade? Maybe you put it back in backwards. Just kidding, well kind of. Quote
Pwalter5110 Posted March 21, 2013 Report Posted March 21, 2013 You say you cut a lot of 8/4 wood. More times than I can count, I have come across some 8/4 wood that twists as its being cut and tries to close on itself. I have a riving knife on my saw, and when the wood pinches closes its next to impossible to push the wood any farther... Everything else has been covered Quote
jgoeden Posted March 25, 2013 Author Report Posted March 25, 2013 All, Thanks for all of your help and advice. I'll try and reply to everyone: NO, the blade is not on backwards ;-) Pat, I've had some curl on me too, I accounted it to where I bought the wood maybe still being a tad wet, the moisture heating and warping it.... don't have a moisture meter though, so that's speculation.. Beech seems to be the worst, maple does it every now and then too... I ended up getting a great deal on a Steel City 10" cab saw for $600, only 4 years old, came with mobile base, 2 Freud blades, brand new zero clearance throat plate and a dado plate.. Sound like a good deal? I thought it was, so I bought it, haven't ran 220 in my garage yet so it's just sitting there :-( screaming at me to fire her up!! Anyways thanks again for all the help, Still going to investigate the Dewalt and put it up for sale. Quote
