krtwood Posted April 17, 2013 Report Posted April 17, 2013 I'm pretty sure the motor for my table saw has a bad bearing. It's been making an intermittent low sort of vibrating squeal which I've been pretending not to hear for quite a while since it didn't seem to be affecting the cut at all. Now once in a while the blade will suddenly vibrate and then settle back to normal. I took the belt off and it makes the squealing noise without the belt. If I rotate the shaft by hand there will be one spot that produces a pronouced squeak coming from the fan end of the motor, which it still does with the fan cover and fan removed. If I run the motor the spot will have moved to a different location. I don't feel any play in the shaft but I'm assuming this is a bad bearing. But I really can't be sure if the recent vibration issue is related to it or if there is a second issue. Would replacing a bearing(s) in the motor be something a typical woodworker can do or do I need specialized tools for this? I'm guessing that having it done professionally is not going to be much cheaper than buying a new imported motor. Throwing a couple hundred dollars at a saw that's worth maybe $300 in good shape doesn't seem that productive. I've been thinking about an upgrade to a Sawstop. I do enough work to justify having a better saw but was planning to wait until I move in about 3 years. But 3 more years is a long time to continue to be frustrated with the limitations of a saw. I can't really afford to be without my saw for any length of time, so the idea of tearing into the motor without anything to fall back on isn't something I'm too keen on. I haven't sold myself on how spending $3k instead of $200 is saving money yet though. Quote
Levi Rathje Posted April 17, 2013 Report Posted April 17, 2013 What type of motor is it? There are some major differences between a universal bench top saw motor, contractors saw, & a cabinet saw motor. If you can figure out what type of motor(brand) you will be able to find exploded view and should be able to replace them your self. Quote
krtwood Posted April 17, 2013 Author Report Posted April 17, 2013 It's a 1.5 hp motor on a contractor saw. No name brand just says made in Taiwan on the plate. Do you have to have a bearing puller to get the old ones off? I could get some cheap ones from harbor freight. Quote
Trip Posted April 17, 2013 Report Posted April 17, 2013 If you have a bearing puller, it's not a big a deal. Harbor Freight? -- not to sure about that choice... Before I got my puller, I went to my local auto repair place and paid them $5 to pull the bearings. Quote
STL Woodguy Posted April 17, 2013 Report Posted April 17, 2013 Harbor Freight does have bearing pullers that do the job, but sometimes I've found that the jaws are too large to get under some bearings, depending on what it is and where it's mounted. If that's the case, Autozone has a simple no-frills bearing puller for $5-7 with thinner 'L' type of jaws that'll slip under the bearing and do the trick. As said, the best puller simply depends on the situation. Quote
krtwood Posted May 1, 2013 Author Report Posted May 1, 2013 Well I finally got the bearing puller, but I should have tried taking the motor apart first before I did that. I didn't really know what to do after I took out the 4 long bolts running through the motor, nothing became loose and I didn't really want to pound on it randomly. But that's not why I shouldn't have done that first. WIth the motor off and out of the way I was able to actually get in to the arbor and while it doesn't move around while under the tension of the belt, with the belt off it wobbles all over the place. So the motor is the least of my worries now. I think it's cabinet saw time, and I can decide if I want to try to fix this one up at my leisure before selling it or get rid of it as is. Quote
krtwood Posted May 21, 2013 Author Report Posted May 21, 2013 Well after a long wait I finally got the arbor bearings and took out the arbor and now I'm really confused. Both bearings look fine and spin freely. The arbor itself is worn where it contacts the outer bearing. How did a working bearing wear out the shaft it was on? The area around the worn area measures .625 while the worn area is .615-.617. Looking on the parts website the picture of the arbor is smooth there so it's definitely not supposed to be like that. Now I get to wait for a new arbor... Quote
TRBaker Posted May 21, 2013 Report Posted May 21, 2013 Krt, years ago I fought a similar issue with my Delta Contractors Saw and finally threw my hands up, went to Grainger and just bought a new motor. I increased my horsepower and solved all the other issues for peanuts, compared to a new saw. Quote
Spencer_J Posted May 21, 2013 Report Posted May 21, 2013 Krt, if i didnt need my saw every day, i'd do what you are doing. However, i use my saw every day and i am planning to get my 3hp 1ph cabinet motor rebuilt in two weeks. The electric motor shop quoted me $155 for new bearings a cleaning and new cord/ strain relief. My motor is doing the same squeek as yours.. No blade wobble though. I have a '70 rockler delta unisaw and its wonderful. Good luck with your parts hunt. Quote
