Darren66 Posted May 26, 2013 Report Posted May 26, 2013 Hi I'm very new here. Im currently coming to the end of an unnecessarily prolonged build! This is my 6th and without doubt biggest and most ambitious project. It's a kingsize bed based upon a design from Cabinetmaking a Foundation Course by John Bullar. I shortened the height of both the headboard and footboard, partly for aesthetics and partly because we have sloping ceilings in our bedrooms. Overall I think its gone reasonably well so far, I'm particularly pleased with curves in the lower rails. However while the mortise and tenon joints fit snugly the shoulders clearly needed a bit more work; slight gaps at points. I'd blame the chisel but its an LN so no excuses! The other problem is that not all the slats touch the lower rails; I think In hindsight the upper rails may have moved slightly, when dry fitted a few weeks ago the slats touched at the ends and in the middle. Not now glued together :-) Photos attached of headboard. And any suggestions on how to ensure all the slats fit better next time welcome. And yes there are 30 slats each end. Quote
bobcrosley Posted May 26, 2013 Report Posted May 26, 2013 Darren, Welcome! The bed is looking fantastic. I know the photos don't show every detail, but I looked very carefully at them and I think you'll be the only person who can see the flaws. What technique did you use for making the mortises and tenons? Quote
Darren66 Posted May 26, 2013 Author Report Posted May 26, 2013 Darren, Welcome! The bed is looking fantastic. I know the photos don't show every detail, but I looked very carefully at them and I think you'll be the only person who can see the flaws. What technique did you use for making the mortises and tenons? Bob thanks for the feedback. I drilled and chopped the mortises; I sawed and chiseled the tenons. This is the first time I've done double tenons. On previous projects I've routed and squared the mortises and routed the tenons using an off cut on the router fence. Hope that makes sense. Probably go back to routing them. Quote
TRBaker Posted May 27, 2013 Report Posted May 27, 2013 Hello Darren, and welcome to the forum. Great job on the bed. Are you slats mortised into your rails? Are your rails still straight? Sometimes they will move once you've milled them from the original lumber. A lot of the members here recommend that you rough mill the boards, oversized and then stick dry them for a few days. Then recheck for straightness and finish milling. If the rails have bowed, this would explain why the slats no longer reach. Several clamps should take care of this issue. Quote
Darren66 Posted May 27, 2013 Author Report Posted May 27, 2013 Hello Darren, and welcome to the forum. Great job on the bed. Are you slats mortised into your rails? Are your rails still straight? Sometimes they will move once you've milled them from the original lumber. A lot of the members here recommend that you rough mill the boards, oversized and then stick dry them for a few days. Then recheck for straightness and finish milling. If the rails have bowed, this would explain why the slats no longer reach. Several clamps should take care of this issue. Hi TRBaker, thanks for the reply. The slats are dowelled in using 8mm beech dowels; I did consider mortising them in, but decided that I would follow the plan from the book regarding joints; hoping they will be strong enough. I think you might be right about some movement I haven't checked with a straight edge yet, but will. Small amounts of movement has been a minor problem on each of my projects, I'm definitely going try milling close to finish and then leaving it for a short while. I've tried storing the wood inside, milling to size in the garage and bringing back in rather than milling and leaving in the garage, but still get some movement. I did try pulling the rails in with a clamp unfortunately my cheap aluminium sash clamps weren't up to it, and started flexing; reassuringly the oak didn't flex! Quote
Darren66 Posted May 31, 2013 Author Report Posted May 31, 2013 Almost there. Side rails to support mattress slats glued and screwed on. Picture attached. All parts sanded to a finish before fitting. Weekend of waxing! Intending to finish with Osmo Wax Oil. Quote
Darren66 Posted June 1, 2013 Author Report Posted June 1, 2013 1 of 2 coats clear Osmo polyx oil. Brush on, and optionally wiped off, 'minimises' colour change. 1 Quote
G S Haydon Posted June 1, 2013 Report Posted June 1, 2013 Looks great Darren. Osmo was a good choice. Quote
Darren66 Posted June 3, 2013 Author Report Posted June 3, 2013 Finished bar the plugs to cover the bed bolt heads! Just need to make some matching bedside tables. I reused the mattress slats from the old bed as it wasn't nice enough or needed anywhere else and they were hard wood of some description and I can't bear wasting wood. Quote
TRBaker Posted June 3, 2013 Report Posted June 3, 2013 Darren, you did a fantastic job. Give yourself a pat on the back. Quote
chicks82 Posted June 4, 2013 Report Posted June 4, 2013 That bed is sexy! Well done sir, well done. Quote
Egraff Posted June 15, 2013 Report Posted June 15, 2013 Darren, you did a lovely job here. I agree with you... the curve on the bottom rails is BEAUTIFUL!!! - EG Quote
Darren66 Posted June 18, 2013 Author Report Posted June 18, 2013 EG2011 thanks for the feedback. It's particularly appreciated as I tend to see the things I could have done better :-) Quote
baok Posted July 2, 2013 Report Posted July 2, 2013 Wow, this looks fantastic. I'm currently working on a very similar project - perhaps I'll post it here. Very nice work. I'm the same way - I see all the flaws in my own work. The best I can do is try and avoid pointing them out to others. Quote
