William Russick Posted June 30, 2013 Report Posted June 30, 2013 So I'm currently online looking for my first router and I think I found something pretty nice in my price range. http://www.amazon.com/Black-Decker-RP250-4-Inch-Variable/dp/B000IEFIBO/ref=sr_1_4?ie=UTF8&qid=1372630783&sr=8-4&keywords=plunge+router Any feedback about this tool? Good bad whatever, let me know your opinions please. Maybe recommendations for something else in my price range? All opinions are respected here, folks. Thank you. Quote
rodger. Posted June 30, 2013 Report Posted June 30, 2013 You are definately going to want a router with a 1/2" collet. The larger shaft is safer and yields better results than a 1/4" bit. The larger collet will also allows you to spin bigger bits, like those use for raised panels. From the brief description, it appears that this router only has a 1/4" collet. You may be able to get an additional collet as an aftermarket product. 1 Quote
..Kev Posted June 30, 2013 Report Posted June 30, 2013 Agree with Pug! I'd look for something that takes both 1/4 and 1/2 with the most HP you can afford. My first was a Makita (about 130 bucks). It did ok, I've since installed it in one of my router tables. Then, I upgraded to the Bosch plunge router (about 200 bucks) and still love and use that one! Then, I upgraded to the Festool OF1400 and love that one too. This is one of those areas that if the cost difference is 50 bucks, wait a little longer and buy the upgrade. You won't be disappointed. 1 Quote
William Russick Posted June 30, 2013 Author Report Posted June 30, 2013 Thank you both very much. I was looking online and there seems to be a big difference between a 50-90 dollar router and a 150-200 dollar router. So I guess I'll have to wait another couple weeks and buy something a little more up there. Quote
Michael Garrett Posted June 30, 2013 Report Posted June 30, 2013 Are you going to use it hand-held or table mount? Quote
knotscott Posted June 30, 2013 Report Posted June 30, 2013 I can't help but think this Craftsman is a better router at that price point....a plunge base is available for it. I'd wouldn't recommend the B&D. Ditto Michael Garrett's question.... Quote
wdwerker Posted July 1, 2013 Report Posted July 1, 2013 I would look at the Porter Cable, Dewalt, Makita, Bosch or Freud routers. Quote
Tom King Posted July 1, 2013 Report Posted July 1, 2013 If your price range is under a hundred bucks, get a slightly used Porter-Cable 690 off ebay for 90 to 100. Cheap plunge routers are not worth the trouble. Check woodworking suppliers online too. Fairly often there is some sort of promotion on the 690, where you get another tool free if you buy one. I've bought several 690s when they came with the smaller router free that's normally about a hundred bucks itself. I keep several of the small ones with various roundover bits, so I can grab one quickly without changing and adjusting a bit. The 690 is a very good basic router that you can do a lot of different things with, and they last a LONG time. 1 Quote
EdgewaterWW Posted July 1, 2013 Report Posted July 1, 2013 Are you going to use it hand-held or table mount? +1 on the Use. I would look at the Porter Cable, Dewalt, Makita, Bosch or Freud routers. He did list the top brands. All the info posted is good, !/2 collect, most HP that You can buy. I went from a creap Home Depot Bosch to a Craftsman Kit (fixed and plunge 2.5hp, same as model #27680) to Porter Cable 892, with more to add. Remember a Plunge base can be used like a fixed base, just lock it in one spot. So if you're only getting one base I would go for fixed base. Quote
Tom King Posted July 1, 2013 Report Posted July 1, 2013 This close to the first of next month, wait a few days and see if another Porter-Cable promotion comes up. Quote
William Russick Posted July 1, 2013 Author Report Posted July 1, 2013 Are you going to use it hand-held or table mount? I'm going to use it handheld right the time being until I build up a little more tools and experience and then when I can afford it, I'll buy a real nice quality router table. This is just a nice start. Quote
