Craftsman is no better than Ridgid in my opinion. CPO has the Bosch drill and impact driver combo set for 179 this week.
Dang...that's some good deals. Bosch, Milwaukee, and Dewalt kits for $200.  Are these new or refurb?
I have the DeWalt 12V combo. Got both for $199.00. Two batteries and a charger. I know it sounds crazy and at the time didn't think it was that big of deal, but they came with a belt clip. It's the handiest thing. The tools are light weight so you can hang them on your belt or pocket and they are always right there.
Timer and charging station when the tools are not in use. When I am working I rarely over charge since I put the battery back in a tool almost as soon as it is charged. The best tip I ever heard for tools at rest was to leave batteries in the charger and put the charger on a timer that gives it power 30-60 minutes a day. This did not work well with original batteries that suffered from memory issues but works well enough with modern batteries.
I've been kicking around a couple of options... my current battery (14.4) won't even drive one screw into a pre-drilled hole. I've been using the tailed drill or the drill press for my drill needs, and been thinking about a brace (but my hand drill technique really sux...)
So thanks for all the input, guys. Do all you keep more than one battery? And do you charge them at the same time or swap one out for the other when it dies? (and do you use a timer for the battery charger?)
Used to work for a guy who set up all of his drills to operate on the same battery, so all the drills were the same brand. Imagine 15 drills, and each having 3 batteries... with none of them marked which battery goes to which drill. Mornings when guys were collecting their gear were horrendous at the shelves where the batteries were supposedly being charged if someone forgot to leave the light switch on... (wall outlet was powered by the switch.)
I have 2 different sets, with 5 batteries. I typically have one battery on the go of each set, with the others charging. Seems to work fine, unless I forget to put one on the charger. Batteries charge in 20 min.
Mine are all 18v NiCad. I need to switch over, as I find them quite heavy for more than light use.
I love my Bosch 12v, it does most of the tasks. I use my corded one for mixing concrete or heavy stuff but the bosch with 2 batteries is perfect. I got a lightning deal on amazon around chrismast for 75$ I also got they oscillating tool for around 80$. So 4 batteries, and they recharge as far as I use the other ones anyway.
I went on the bosch after reading reviews and seeing test, it came up #1 in most reviews.
  • Who's Online   2 Members, 0 Anonymous, 55 Guests (See full list)
