I recently did some drilling with a brace and auger bits. I had trouble with keeping the bit vertical as I rotated the handle around.
Any advice as the the proper body English to use in this scenario? Other than holding a block of wood with a square cutout up to the auger as a guide?
rest your head on the pad of the brace and you can sight down to see if you are square. Or place 2 squares at right angles to your bit so you have 2 reference points. Once you get the lead screw in stop and check you have gone in straight if you have you should be good to go. I have done very little drilling but this has worked for me.
If you're trying to drill square, set the drill parallel to the floor and drill straight in.  It might mean moving the stock upwards until you've found a comfortable location to support the drill bit and keep the stock steady, but it's possible.  Also, there's a trick that Bob Rozieski (spellling not hapeninngt today) and Shanon Rogers have demonstrated - perhaps even mentioned a time or two? - about drilling.  Namely, the circular pendulum around the drill bit.
My version of this is to take a larger eye bolt, and use some noticable nail polish.  coat the nut with the nail polish (I had one that was almost neon yellow, until someone under the age of 18 scraped it off), and it dangles under the drill bit.  If I can see the bright flash of neon, I know I'm not square.
This only works for left to right approaches on the board, and when the board is perpendicular to the ground.  But as the bolt is lying across the bit, you can see whether it's straight across or angled slightly, which will address the "up or down" angle of drilling.  And again, this only works perpendicular.  But it's the only method I've found (for myself, anyway) of keeping my holes bored and straight without using a drill press.
Yes to all of the above.  Another thing to consider is you want to keep your stroke consistent.  If the bit is really hard to turn and you have to really lean into it to make the rotations or find yourself stopping in mid turn to shift from push to pull this will translate to the bit and produce either an out of square hole or an oval.  With a smooth rotation the bit can do its job and you will get a squarer hole.  So keep your auger sharp and keep the brace speed up and it will dramatically improve the performance.
