mcooley Posted September 20, 2013 Report Posted September 20, 2013 Hi All, So here is a chair-bench design I am completing. I have a couple weeks to go! But I have a quick question. I am realizing now that I might like the piece to TILT back. Is this a good idea? Something tells me it isn't as simple as removing material from the back two legs and changing the angle of the bottom front two? Or is it? Thanks! Quote
duckkisser Posted September 20, 2013 Report Posted September 20, 2013 as long as you dont remove so much that the weight of the back throws it off and sending falling backwards. i would not change it so much its like an andorandeck chair but a few degrees would probably make it more comfortable. try puting a couple of small blocks of wood on the front to find the angle you like. Quote
mcooley Posted September 20, 2013 Author Report Posted September 20, 2013 I was considering just a couple degrees, so, very slight. Thanks Quote
G S Haydon Posted September 20, 2013 Report Posted September 20, 2013 Duck makes a good point. BTW, that is an awesome design mcooley! Please post pics when done. Where did you find the inspiration? 1 Quote
mcooley Posted September 20, 2013 Author Report Posted September 20, 2013 Thanks! Some combination I guess between Maloof, Esherick and my own sculptures. First time making furniture. Learning curve is huge! Quote
Byrdie Posted September 21, 2013 Report Posted September 21, 2013 Lay a long straight edge even at the front corner of the front leg and across the back leg. Raise it up the back leg the amount you would like to cause the bench to tilt and draw your line. Mirror it on the opposite side. Duck's point about not adding too much of a lean is valid but I think a little bit of slant would be fine and add some comfort as well as add to the appearance. You can play with the feel by putting shims under the front legs until you get a feel for what looks right. Quote
Freddie Posted September 21, 2013 Report Posted September 21, 2013 Yea let us know how this all turns out, it looks freaking awesome as it is already! Nice job Quote
mcooley Posted September 22, 2013 Author Report Posted September 22, 2013 Will do! Thanks all. Think I will do this at the end. Now on to some of the details. Quote
Egraff Posted September 23, 2013 Report Posted September 23, 2013 You probably have to sit in it to tell for sure (vs looking at photos online), but to my eye, a bit more tilt to the back certainly wouldn't hurt things here.... This is a very interesting piece. I'm looking forward to seeing a photo once you complete the project!! - EG Quote
mcooley Posted October 10, 2013 Author Report Posted October 10, 2013 Okay, so, nearly done! I need to do some more detail work but pretty much done. The right bench side is kind of part seat and/or where you could just leave items like books, blankets, etc. More sculptural, I suppose. Used Maloof oil this time instead of Good Stuff. Much easier to apply. It's all made of alder except for ebony highlights. A couple spots are walnut like trim etc. I can post better pics of all sides when it is ready. Thanks Quote
Trip Posted October 10, 2013 Report Posted October 10, 2013 Great design - congrats... One thing, I'm a bit worried about the right-hand-side back support... Around our place, outdoor furniture undergoes a fair amount of hard use... I really can't tell how thick the support is... will it last? Quote
mcooley Posted October 10, 2013 Author Report Posted October 10, 2013 Yeah, this is for indoors - luckily! But I am going to be inserting another piece of wood to contrast the alder so it won't be so fragile. But for now it is a tad bit flexible! Thanks Quote
mcooley Posted October 10, 2013 Author Report Posted October 10, 2013 Thanks! And what is that piece on your profile pic?! Quote
Byrdie Posted October 10, 2013 Report Posted October 10, 2013 I think it's a shave horse but I'll let him answer. Quote
mcooley Posted October 11, 2013 Author Report Posted October 11, 2013 Finished! Except for some minor changes later but for now it's done. 1 Quote
mcooley Posted October 11, 2013 Author Report Posted October 11, 2013 Thanks! A friend calls it a Chench! Quote
