Milo Posted September 25, 2013 Report Posted September 25, 2013 Hey Everyone, hoping one of you electrical types can tell me if I can do this or not. I want to hook a timer into a surge protector that I want to use for charging my drill batteries. Unfortunately, while I was expecting the timer to be like a light switch, with the incoming wires and the outgoing wires. Instead there is one set of 4 wires, red, white, green, and black. Here is a picture of the timer and the wiring I want to splice it into, plus the instructions. I THINK I understand what I need to do. I believe I need to add an additional white wire. If you can verify this and give me any advice on how to adapt the instructions to the wiring, rather than an outlet, I would be grateful. Thanks! Milo Quote
bgreenb Posted September 25, 2013 Report Posted September 25, 2013 Not a professional electrician here, but I've installed plenty of these timers and have done my own outlets and new circuits. First divide the cable going to the surge protector (i.e., cut it). So now you have two sets of "surge protector" wires - one set connected to the plug and one set connected to the actual surge protector. So 6 wires - two each of black, white, and green. Then you have the switch/timer, which has another black, a red, a white, and a green. Start with the simple part - connect all three white wires together via a wire nut. Do the same with all three green wires. Now connect the black from the TIMER to the black that is connected to the PLUG (this is your "hot" or "line" wire). Then connect the red from the TIMER to the black that is connected to the SURGE PROTECTOR (this black wire is your "load" wire and the red wire is the switched wire in the timer). Make sense? No need to add any extra wires. Quote
Milo Posted September 26, 2013 Author Report Posted September 26, 2013 I will try that! Thanks for the advice. I'll use a stick to turn on the surge protector, just to be on the safe side. Quote
bgreenb Posted September 26, 2013 Report Posted September 26, 2013 Keep in mind that this solution is definitely not to code and is not really very safe - you're going to have a hot wire that is protected only by a wire nut. If I were doing this personally, I'd install this switch/timer in the wall and have it control the outlet that the surge protector will be plugged into. Or at the very least, I'd be using heat shrink crimp connectors so no wire will be exposed. If there will be kids anywhere near this, or even pets, I would think carefully about whether you really want to do this. The solution I gave you above will work, but once again it's not the safest thing in the world. Quote
bgreenb Posted September 26, 2013 Report Posted September 26, 2013 Cool, let me know how it turns out. Quote
wtnhighlander Posted September 26, 2013 Report Posted September 26, 2013 I second what bgreenb says concerning the safety of this arrangement. The time you have is intended to take the place of a manual switch (light switch), mounted in an appropriate enclosure. At the very least, you should install this timer in, and make all the wiring connections inside an electrically-rated enclosure, with strain reliefs on the cords that enter and leave the box. Quote
bgreenb Posted September 26, 2013 Report Posted September 26, 2013 I second what bgreenb says concerning the safety of this arrangement. The time you have is intended to take the place of a manual switch (light switch), mounted in an appropriate enclosure. At the very least, you should install this timer in, and make all the wiring connections inside an electrically-rated enclosure, with strain reliefs on the cords that enter and leave the box. Yes, that could be a happy medium. Install the timer in a 1-gang box from Home Depot. Get a cover for it and fasten it to the wall or your bench base or something. Then all the wires flow into the box and all the electrical connections are enclosed. Obviously still not code but MUCH safer than just leaving it all out in the open. Quote
Trip Posted September 26, 2013 Report Posted September 26, 2013 Instead of splicing something into an appliance with all the safety issues involved, why not get a purpose-made timer? http://www.globalindustrial.com/p/electrical/timers/electromechanical/table-top-lamp-and-appliance-timer?infoParam.campaignID=T9A&gclid=CPOAtrDy57kCFUmY4AodZnkAyg Quote
bgreenb Posted September 26, 2013 Report Posted September 26, 2013 Instead of splicing something into an appliance with all the safety issues involved, why not get a purpose-made timer?http://www.globalindustrial.com/p/electrical/timers/electromechanical/table-top-lamp-and-appliance-timer?infoParam.campaignID=T9A&gclid=CPOAtrDy57kCFUmY4AodZnkAyg Even better. Quote
Milo Posted September 26, 2013 Author Report Posted September 26, 2013 I just thought having a "hot tub" type timer would be easiest. I didn't want one of those away times that turned on from 8 - 5 and off for the rest of the time. The plan is for my charging station. I just want to be able to put all my batteries on their chargers, set the timer, and 30 minutes later the whole station is shut down, and none of the batteries suffer from that "trickle" effect that damages them over time. Nuts? I can still punt, tape up that surge protector, and plug everything in direct. Opinions? Quote
Tpt life Posted September 26, 2013 Report Posted September 26, 2013 Bath fan timer to recept in a two gang box, plug in your surge protector. Still not best. Best practice is to remove the batteries from the charging stations transformer. You risk run down leaving the batteries sitting in the station a lot. Quote
Trip Posted September 26, 2013 Report Posted September 26, 2013 ==> I didn't want one of those away times that turned on from 8 - 5 and off for the rest of the time. So, something like this? http://www.amazon.com/Woods-Import-Digital-Countdown-Timer/dp/B001DD7YSE/ref=zg_bs_6291360011_17 Quote
Tpt life Posted September 26, 2013 Report Posted September 26, 2013 Trip H, I cannot find specs but would caution to check wattage ratings with multiple battery chargers. Some of those less expensive timers are low wattage consumers only. Quote
Milo Posted September 26, 2013 Author Report Posted September 26, 2013 ==> I didn't want one of those away times that turned on from 8 - 5 and off for the rest of the time. So, something like this? http://www.amazon.com/Woods-Import-Digital-Countdown-Timer/dp/B001DD7YSE/ref=zg_bs_6291360011_17 Yes, closer, but that one had similar reviews about the internals frying! ack! Beside, don't we all long for our own jury rigged systems? I know I do! You should see my dust collection system! Bath fan timer to recept in a two gang box, plug in your surge protector. Still not best. Best practice is to remove the batteries from the charging stations transformer. You risk run down leaving the batteries sitting in the station a lot. Exactly the plan! This way I put the batteries on the charger, set the time, and in 30 it turns off and I don't have to find a third space in my tiny shop for the batteries. Also, I can hit the "on" button when I go in the shop, and (hopefully) the batteries are ready when I need them. Quote
Milo Posted September 26, 2013 Author Report Posted September 26, 2013 I second what bgreenb says concerning the safety of this arrangement. The time you have is intended to take the place of a manual switch (light switch), mounted in an appropriate enclosure. At the very least, you should install this timer in, and make all the wiring connections inside an electrically-rated enclosure, with strain reliefs on the cords that enter and leave the box. Already had that planned, just didn't have it in the pictures. Sorry to worry folks. Quote
Trip Posted September 26, 2013 Report Posted September 26, 2013 If you cant find an in-line device that fits the bill, then the right thing to do is mount the timer in a 2-gang box with an NEMA-15 outlet... I'd split the outlet and make one side timed and the other constant power... Quote
Tpt life Posted September 26, 2013 Report Posted September 26, 2013 Trip H for the win! Never thought about splitting the recept :-) Quote
Milo Posted September 26, 2013 Author Report Posted September 26, 2013 Here is the final product. I've had problems with burned out batteries in the past, so I decided to take a shot at this and see what happens. It has the added plus of getting my drill out of the way and putting them all in one place. Here's a pixs... The first is a shot of it up on the wall. Sorry it's hidden behind the bandsaw in the second. Thanks everyone for all the help. Milo Quote
bgreenb Posted September 27, 2013 Report Posted September 27, 2013 Looks great! Glad I could help. Quote
