Shop built air filtration unit
I know there have been many discussions on the need and performance of air cleaner/purifiers. However, I believe that it will help clean the air in my shop.
My plan is to build my unit using a squirrel cage fan from a Jenn-Air kitchen fan, installed in a 16"x16"x20" box. I plan is to us 2 layers of 1" semi quality pre-filters which will slide into dados in the box.
My question is, what do you all think about instead of using an expensive hepa filter as my final filter, to rig up a bracket on the end of the squirrel cate fan? I would then use a piece of all-thread screwed into the bracket and install a shop vac type hepa filter onto the all-thread, thus reducing my cost of expensive 16"x20" hepa filter, to just the (still costly) shop vac type hepa filter?
Thanks for any and all opinions.
Jim
I've thought of doing the same thing only my idea involved an air cleaner/down draft, the air would be pulled through the grid of holes in the top of the table than through the filter exiting the table. I think standard furnace filters would work just fine.
You may want to rethink the dado idea. As the filters start to load with dust. The dust will work around the dado and into the fan. Have an opening where the filter seals tight against the opening and latched down. Look how higtron has it in the drawing.
Mine is set up that way and have had no issues with the fan getting dusty.
-Ace-
I've seen one plan for a bench-top downdraft that doubles as the air filter.  It does run two squirrel cage fans in series, and supposedly has decent suction (even with all the holes on the downdraft).  It's a 3x3 or 4x4 (don't remember exactly which at this point) that runs through two of the long yet narrow filters that run about $5 each.  I was tempted to do something like this and connect it to a shop vac, but higtron's works far better.  Fill that dead space with drawers, and put your sander and sanding supplies in it.
Thanks for all the suggestions. Helped me out alot. I will hopefully start building this next week and will keep you all updated.
Jim
Not sure if you got the info you needed, but I built one for my shop based off of these plans.  It is designed to wall or ceiling mounted.  I have not gotten around to that yet, as it is damn heavy and I don't have a good spot for it.  It does do an excellent job though.
I don't have the best dust collection system yet, improving but not great, and I get very little to no dust settle after a day of woodworking when I have this thing running.  You do have to clean or change the filter regularly though.
I set mine up for two pre filters, but find the air flow is better with only one, then I have a more expensive filter on the output side that picks up the small particles.
I am very happy with it, and it was pretty easy to build.   I have less than $75 in it, and I had to buy the squirrel cage, plywood, and the switch.
ShopAirFilter.pdf
I used 20 inch box fans with the best quality 20" furnace filters on the input side.  I have two hanging from the ceiling for general shop air cleaning and two built into a hood over my lathe.
I make a practice of vacuuming the filters each time I clean the shop.  Depending on my projects I find there is a significant amount of dust caught in the filters.  I use the house vacuum system which vents outside to clean the filters so I don't recirculate the dust into the shop.
It takes a lot of fan to move enough air to make any real difference. Furnace filter stuck on box fans and the like will collect some dust but they wont do even a fraction of what they should. Get yourself a cheap manometer to play around with these diy projects before investing any money. It takes 4 box fans with floss filters to move enough air through a 2'x2' opening to be close to minumum spray booth requirements. Use furnace filters like heppa's it takes closer to 12 box fans for a 2x2 opening. Any air movement will collect some dust but their is a point where you really are just wasting electricity.
  • 26,009 Total Members
  • Joseph b Newest Member ·
