I want to start off by saying that I own a PC drill press from lowes. Out of curiosity while in the shop tonight, I hooked up my dial indicator with magnetic base to test the runout of my drill press. I set the dial to zero and started it up. Its hard to read since the dial was fluttering back and forth so fast. Against the bottom of the chuck it fluttered between 0 to 10 thous. Then I stuck a forstner bit in the chuck and ran the dial on the straight part of the shaft. It was fluttering to fast but I think it was 7 thous. I know it is an inexpensive model, and it has been more than fine for me, but what is tolerable for drill press runout in woodworking?
Freddie, I have the same drill press. I haven't had a chance to measure the runout, but I know it is too much. I will measure tonight after work and get back to you with how much mine has. I have read that a new chuck fixes most of the runout. I may eventually go that route. My chuck key doesn't feel like it is the right size for the chuck either, it feels like it is stripping every time I use it. But it has a lot of bang for the buck, hopefully with a new chuck it will be fixed right up.
Put the dial indicator away. Worry more about slop than run out. Lower the quill all the way down and check for slop. You don't need to be so concerned unless your machining metal parts for something important.
8' sam, i have an 8' dial indicator.
For those who say size doesn't matter...
Anyway, what I was getting at is how far your point of measurement from the source was. A forstner bit is like 5" right? So the total deviation of a 5" bit at 0.007" is pretty reasonable I think. I'm no perfectionist, though.
My first test was directly on the chuck, then at the top of the bit, maybe a half inch from the chuck.
That's interesting. Maybe the chuck isn't perfectly cylindrical, or mounted off the axis, causing the extra bit of deviation.
I've never measured drill press runout/slop, or anything like that, so I don't know if things like this are normal.
What would you expect to see on a PM drill press? Or, in the woodworking world, what would be your ideal (realistic) runout amount?
I just did this out of pure curiosity, not to prove anything or start a debate on woodworking accuracy for tools, just for kicks.
Oh, yeah, I'm not debating anything. I have no drill press, so I ask from a pure curiosity standpoint.
Completely agree here.  I have never checked my DP for run out and probably never will.  Its also a 20+ year old grizzly I got second had a couple years ago.  I have used it to drill a lot of holes and everyone of them has been where I needed them to be, unless I personally goofed.
My POS Ryobi doesn't have much slop in the quill when you lower it ALL the way down.  But anywhere in between all the way up and all the way down you can see the end of the drill bit move around at least a 1/16th.  It's a very helpful random hole location feature that you can't find on expensive tools.
I had my eye on a Steel City DP, but they pretty much disappeared from the market a couple years ago.  Ah well, I don't really have a spot for a floor model right now anyway unless I block one of the doors with it :)
  • Who's Online   2 Members, 0 Anonymous, 56 Guests (See full list)
