First time using red oak, how do i stain it?
I've done my first engraving with red oak (actually any hardwood), and i'm not sure how to stain/finish the project.
Here is the piece:
I'd like to make the color and grain pop and bring out their richness. I figure i'll do a top coat poly or shellac to give it a satin sheen. Just not sure on how to stain it with the nooks and crannies of the inset text.
I would wipe on a coat of BLO (boiled linseed oil) to pop the grain, let it dry and do a coat of polyurethane or shellac.
Have you considered trying to paint the inside of the letters with black paint to make them stand out? If you paint the letters and then sand the top surface or run it through the planer one last time to clean up the edges before putting on the last finish I think it would look great.
Rog
I've been using a golden pecan stain, but where there are indentations that i want to stand out, I color it with a darker stain, surface sand and reapply the pecan and seal with poly!
If spraying paint into the engraved portion, then resurfacing the flat is off the table, you can ( I have ) stain or paint the engraving with an inexpensive artist's brush of appropriate size. It is tedious work to fill in the gaps while keeping flat clean, though. If you had not engraved it already, I would recommend a layer of masking paper, and engraving right through it.
Thanks everyone! That certainly gives me some good options.
Non-figured grain doesn't "pop." Any finish is going to highlight grain colors and bring out depth and richness in wood. Even clear top-coat will do this. Adding color just makes it darker.
noob question... but what is 'figured grain'? Which wood has this characteristic?
Figure is blotching in a pleasing pattern and, in domestics, is primarily associated with maple and cherry. Your oak isn't figured, so that's not an issue. See Marc's vid on other maple for more.
http://www.thewoodwhisperer.com/videos/pop-goes-the-maple/
You don't want the wood to pop (because it can't) you want the letters to pop. Paint inside the letters and then sand the top to make things nice and crisp. Then hit with linseed oil and you're done. No need for poly on a small, decorative piece such as this.
Nice carving, by the way.
If you get paint or stain in the oak pores you'll be sanding forever to get it out unless you have a drum sander and still you'll have to go deep. I would finish with shellac before painting.
One other 'enhancement' I have used on red oak is colored filler. For this piece, I doubt it would look good, but for future reference:
Commercial grain fillers are available in a variety of colors. Google can tell you where to find them. For the more frugal amoung us, plaster of paris and Rit dye work wonders. My last table project used the plaster with black dye to fill the grain pores smooth, and increase the color contrast, the wood having been left natural. Looks really good under a coat of boiled linseed oil. I plan to try it on 'ebonized' oak, using bright red filler, in a future project.
Beware, one must be prepared for a lot of sanding with this process!
Used golden pecan today, and literally surprised that I liked it. I didn't like the piece before I stained it. It's orangey, which most stain I use isn't.
As for the carving, I use oak all the time. Like they said, anything will bring out the grain, and red oak usually has some nice subtleties in color. I think it would be cool if you used the golden pecan in the engraving and then just either urethaned or oiled the rest.
I tried some basic poly on a scrap piece, and I actually really like it. It gave it a nice warm pecan-like color.
I tend to like darker colors with oak, the yellow look that I most often see doesn't do much for me personally.  On red oak projects I give a coat of shellac, go overtop with a dark glaze (general finishes) then top with arm-r-seal.  If I'm looking for a soft accent from the glaze I tend to wipe most of it off, but if I want more of a mocha tone I'll leave it on a bit heavier.  Looks nice; you can still see the golden shimmer beneath the darker glaze when looking over the piece.  If you really want an old look, you can brush the glaze on fairly heavily and let it dry.  The bristles from the brush add a streaking effect that make it look 100 years old.  Doesn't look painted by any means, but does give a 'rich' look to it.  A few swipes with some steel wool before top coating to add some wear spots and instant antique :-)
You can also glaze with a gel stain.  To do this I like to use Danish Oil first to seal the wood, then follow up with a dark gel stain.  Wipe most of it off and top coat with more Danish Oil, Arm R Seal, or wax as appropriate.
  • 26,009 Total Members
  • Joseph b Newest Member ·
