From the sound of things you are doing everything right and that is giving each purchase very careful consideration.  It sounds as though you are thinking of a jointer as your next major purchase and a jointer is a very good tool for a complete shop.  However to get a nice straight and square edge on a piece for gluing or whatever you can also use a router table with a offset fence.  I admit a jointer would do a quicker job but with proper set up I don't think it would be any better.  A router table also is a very versatile tool and can open up a lot of other options.  With budget and space restrictions it could very well be less expensive and take up less room.  U-Tube is full of very good suggestions for shop built router tables.  Good luck in your future with wood working.  It is a great way to spend your time and as your experience grows so will the satisfaction you get from it.
Dave Harrington
I think it's important to point out to a newbie that a router (or a TS) used to do edge jointing is only doing one of the two main functions of a jointer...."edge" jointing.  The other is "face" jointing, which creates a flat reference face, and is critical in getting a true 90° edge.  For me, step one on the jointer is to flatten a reference face.  Then I place that face against the fence to square the edge.  If you only straighten the edge, and not the face, that edge will have a more random correlation to the face....it'll be 90° at some points, and something other than 90° at other points, depending on the variation of the board.
There are other methods to achieve a flat face besides a jointer.....hand plane, planer with a sled, hand plane and planer in conjunction, router with a trammel sled for flattening the face (tedious), etc.
And this is why I am considering a jointer as my next purchase. Getting a true 90 degree edge to work off of. :-)
Ok, before I get even more frustrated please help me out!
I removed the table and trunnions from the saw and laid them upside down on a couple of saw horses so that I can go through the tedious process of making sure the blade is aligned to the miter slot to less than 4 thousandths of an inch. The problem I am having is making the actual measurement. I've identified a tooth on the blade to use to measure in front and back. The problem is that the Dial indicator I have is very sensitive and I can't figure out how to get it to stay completely in place while moving it from front to back. I tried using my Digital Vernier Caliper without much success as well.
So please help! How can I get an accurate measurement from the blade to the miter slot in both front and back?
Here are some pics of my current state --
And my Indicator base :
So any and all help appreciated!
Thanks!
I clamp my dial indicator base to the miter gauge. Clamp high enough that it doesn't drag on the table. Some like to make a wood base for it which runs in the miter slot.
Duh! Should have thought of that! The heatwave here in the midwest is getting to me. My garage shop is like a sauna right now so I can only spend a few minutes at a time out there in the heat.
I've seen a few of the wood bases that run in the miter slot and I tried that, but couldn't get it to be tight enough not to have a little play in it each time I tried taking a measurement.
Thanks!
Edit - Ok, so I clamped the indicator to my miter gauge and with out touching anything, I get a reading of 35 (0.235) on the front and a reading of 60 (0.260) on the back at the same tooth. So that makes the blade off by about 25 (0.025) or 25 thousandths of an inch. Yikes!
I just want to verify that to make the correction, I need to give a couple of good whacks on the trunnions to adjust. To make the correct adjustment I want to move the front of the blade ( the smaller reading) away from the miter slot while moving the back of the blade (the larger reading) closer to the miter slot.
I also want to leave one trunnion bolt tightened while making the adjustments.
Correct?
Thanks!
Tim
Update --
So I gave the trunnions a good whack and got within 0.002 (2 thousandths of an inch) from front to back. However when I went to tighten the trunnion bolts, and recheck, my readings were way off again. So I tightened the front two bolts and loosened the back two and adjusted and tightened a little and adjusted and tightened a little.
Now the readings I get are 39 (0.239) at the front and 39(0.239) at the back!
However, I'm concerned because while the back reading is pretty tight, the front reading can vary up to 7 thousandths of an inch due to play in the miter gauge in the miter slot. The miter gauge is tight in the back but has quite a bit of play in the front.
Any suggestions ? I want to get my blade as close to parallel to the miter slot as possible and be 100% certain of the readings I am getting.
Thanks!
Edit -- I went back out to check again and realized that the play wasn't in the bar or the slot (measured both with my digital caliper to verify there was no variation along the slot or bar) and that it was in the gauge itself. So I tightened up the gauge and without any play I get readings within 0.002" from front to back, acceptable to me!
Now to put everything back together and make adjustments to the fence.
Thank you all! I'm still in the process of reassembling everything and making final adjustments, but I'm happy that the blade is within 2 thousandths of an inch front to back both at 90 degrees and 45 degrees and the stops are perfect after getting the table and extensions back on. I put the motor on and need to align the pulleys and square up the fence and I'll be ready to do some test cuts!
If it weren't for the darned heat in the garage and the fact that I have to travel this week! :-)
So I really couldn't wait, and so finished up everything today. Here is a pic of my first test cut! Ran it through the blade to square up one end of a scrap just to see how it came out.
Looks square to me! Cant wait to start working on somethings now!
Looks like you have a machine worthy of some fine sawdust! I know that setup was a pain, but at least it is a one-time deal. Unless you move to a new shop, or othewise stress the crap out of the tool.
My only plans are to move the saw from it's current stand to a mobile routing / sawing center on a mobile base that I'm building so as to save space. The plan is to put the saw on the base along with my router and that way I will free up a cabinet space from no longer needing my bench top router table while at the same time increasing space to the right of the blade. Add on a Biesemeyer fence and should be good to go!
Now if I could only find a decent jointer in my price range. Every time I find a good Jointer under $400 its gone before I even text the seller about it!
Currently don't have a real big need to be able to plane to thickness since I'm really just getting started. Once I can build a couple of things square and get the hang of things then perhaps I will start having a need.
I'd like a Lathe so I could do some pen turning. It'd be nice to be able to turn some pens and build some boxes to generate a bit of income with the hobby, just to try it out and see what it would be like to build and sell something. If nothing more than to generate the money needed to buy another tool! :-)
Lots of debate around bere as to whether a jointer or planer is best to get first. I used to think jointer, but now I'm leaning toward planer, as a planer and tablesaw can do the jobs a jointer is used for, albeit requiring a jig or two to do so. The only tool that can duplicate a planer's function is a hand plane or a router sled. Having tried both, I'll keep my DW735, thank you very much!
