Hi All,
I've been woodworking for a few years and decided to purchase a 14'' Rikon bandsaw this summer.  Most of the projects I've been working on did not require bandsaw work, so it mostly sat with the exception of a few minor cuts here and there.  Anyway, I got a request to saw a small log in half for an arts and crafts type project.  No problem I figured, I'd throw it up on the bandsaw and be done with it.  I certainly didn't want to mess with a round object on my table saw.  This was a pretty small piece; about 6'' diameter by 8'' length.  About half way through the cut, the blade twisted sideways and got bound up, cut the plastic table insert and lower blade guide, and bent the blade.  I dissected the wood piece and verified that there wasn't any metal or foreign objects in it.
My question is, was what happened due to my lack of experience using the equipment and, if so, what should I do in the future to perform this cut in a better / safer way.  Alternatively, is it possible that I did not set the saw up correctly and that's my issue.  I followed the steps to adjust the bearings but it's possible I missed something.
Yeah if you arent centered with the. cut and arent cutting with wood supporting all the way to the table the log may want to twist and kink to the side (grabbing the blade with it like k cooper said).
Also if your feed rate is too high, gullets get clogged halfway through the cut, blade gets too hot (if it has a small set), log is green and the cut gets hot (and starts grabbing the blade), use the fence when it isnt dialed in for blade drift, unsupported cut, etc. all these thinks can cause problems major problems like that.
I have the 1 1/2'hp 14"'craftsman, which is the same saw as the cheaper open bottom rikon, I love the saw and it has done a great job. I was cutting 6" walnut round stock to length and it grabbed it and bounced it off the ceiling, I was using the same 3/4" blade I was using to resaw earlier, it did not damage the saw but it did ruin the blade. I put on a smaller blade with more teeth and had no problem.
I do believe a sled is in order, the saw was cheap and it did not come with a miter gauge or rip fence, I ordered a rikon fence
Set up for it but I have not got a miter guage that fits the slot properly.
I think the wood shifted/turned while cutting and the blade had a catch. Plus one to what everyone is saying about the piece you're cutting needs to be held secure during the cut!
I had a similar thing happen while free-handing an odd shaped piece. Sorta was like a kick-back and bend the blade.
-Ace-
  • Who's Online   0 Members, 0 Anonymous, 52 Guests (See full list)
    26,008
    Bob44
    Bob44
