Grizzly bandsaw bearing stuck ?
I noticed recently my g0555lx wad making a bit more noise I inspected the bearings and it appears both the lower side guide bearings are stuck ?! One popped free and spins rather poorly the other won't budge. I have dust collection on the machine and I brush the parts very frequently. Was I not diligent enough ? The bottom area (directly under the blade often gets dust sitting around it. Also anyone know if carter makes bearings or maybe has anyone upgraded to carter guides on a new grizzly 14 inch?
Mine have the same problem. I don't think that they are very good bearings. But I haven't got around to replacing mine yet.
Odd mines only like 3 months old and gets used like 2 times a week. Any ideas on bearing upgrade folks ? If I go back with oem how do I make sure it doesn't happen again ?
Make sure they are adjusted right. If they are spinning all the time you can burn them up.
Totally . I keep mine close but never ever touching. I basically do the alex Snodgrass method . It seems odd they would stick so quickly
Mine did the same. I took them off and applied WD40 to loosen them. I now apply a good oil like Snake Oil and haven't had a problem since
Maybe if I soak them in it ? I sprayed a ton of empire dry lube on them and have had 0 success. Maybe when I get it back together I'll add a dust port right up at the guides. This one has the port at the bottom of the cabinet.
I just had a bearing seize up recently.  One of the seals actually came off.  I don't know if that was the cause or a byproduct.  I took the other seal off and then it took repeated applications of WD-40 and compressed air before it finally freed up.  You could probably also use bit and blade cleaner but I've never tried it.
Hmm I'll keep trying. Maybe if I can find them I'll order some extras. 200 for carter guides seems cheap however compared to dealing with this crap every three months
That's a good idea. I worry about general thicknesses but I don't see why it wouldn't work. By general measurements I mean like furnace filters and some shop vac style fitting where they are called a certain size but are actually slightly different. Have you ever replaced bearings like this before Mr wdwerker?
There should be a part number on the side of the bearing. I replaced some on my steal city bandsaw bought from amazon. Think they were around $7 a piece.
If it's only three months old why don't you contact Grizzly and see what they say? They will probably send you a new set of bearings, no charge.
Vbx may have what you need. I'd go bigger if you have enough adjustment. Most small saws just have skate type bearings but you can get high speed bearings. What is the shaft diameter and approximate bearing diameter.
