Wood shop is starting to take shape.
Simply put dust collection is key. I have a dedicated sucker on my drum sander. When the filter bag gets clogged and not sucking like it should the dust isn't pulled off the drum and guess what....burning.
My feed rate is always on the lowest setting and very light passes. Shoot guys, the drum sander is to get whatever your doing dead flat. I typically run 80/100 or120. Anything over 120 is just an exercise of waste of money on 120 paper and time and wear and tear on the sander.
You still have to machine sand by hand anyway with an ROS, so whats the point? The 100 grit scratch is not that big of a deal.
Also, if you buy good paper, you can wash the paper. I will spray down the dirty paper, burns and all with ZEP citrus cleaner from the box store. Use a brass BBQ brush and go easy remove the baked on burns. Rinse under warm water and hang the drum sander paper up to dry.
-Ace-
  • Replies 57
  • Views 12.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I have the Kreg perfect fence, very quickly adjustable for drift.  Works very well!
  • And for those bandsaw newbies I will present an alternate view.  Please read this with a positive, good natured tone ;-) I'm from the other camp; I do not acknowledge DRIFT.  In my world it is a
  • Actually, slowing the feed helps..  I run mine on the lowest setting most of the time.
Posted Images
Well I was able to get it sanded down to where I want it. 80 grit and 9 1/2 speed was what I used. No burn and now it's ready for the ROS. I took tiny passes. Just barely went clockwise, maybe a minute. If I went two it would bog down badly. This part of it is going very slow. I know it will be worth it.
80 grit leaves a rougher surface than my planer.  My goal when I bought my drum sander was to save time.  I have to start with 80 on my ROS right after the planer, so using 80 grit on the DS after the planer doesn't make much sense.  I usually keep on 150 or 180 and use if for only flattening a glued up panel, cleaning up a shop-sawn veneer, or removing snipe from freshly milled boards.  I go straight to 120 on the ROS (or hand plane/scrape the surface, depending on size and species) and it takes very little time to clean up the straight lines from the DS.  Cleaning up 80 grit straight lines takes forever with ROS.
It's unfortunate that I had to get the drum sander to begin with because of the end grain cutting boards I'm starting out making. The thickness planer wasn't going to cut it without a grenade happening. The board is still too thick to my liking.
 wdwrkr hit on what I was waiting for. I have a magnet glued to the end of a carpenter's pencil so it sticks right near the controls. I put witness marks down the material to help me judge my stock removal progress. This has helped me to learn how much is to much at various grit and feed speed combinations.
On April 3, 2016 at 7:02 PM, gee-dub said:
I said "The solution seems to be coplaner wheels among other things" ;).  Damaged blades (through wear or misadventure) can certainly make things track poorly.  Other incorrect situations can also contribute to poor tracking.  I have just found that all other things being correct, wheels out of plane can still cause you to chase a solution till the end of time (or until you spend money on some solution in search of a problem) :).
The "experts" I mention are popular demonstrators or magazine article subject who are indeed knowledgeable and talented. Other experts state that coplaner wheels are part of the tool's design and should certainly be present just as belt pulleys should be coplaner on belt driven tools or any other similar mechanical example.  I was just being my typical dry-humored self when I touched on the fact that some "experts" don't agree with other "experts".
In speaking to table alignment, I use jigs and a miter gauge on the bandsaw; not everyone does.  For me having the miter slot aligned with the blade on the bandsaw is just as important as on the tablesaw.  Having the table aligned perpendicular to the blade is also important in some operations as far as blade tracking goes.
Since I apparently cannot be brief :D I will talk about non coplaner wheels on crowned tire machines.  Picture the blade riding appropriately on the drive wheel but, being too far forward or behind on the idler wheel due to being out of plane.  You can see from the pic below how this would cause tracking issues.
I better wander off now before I get the reputation of being a blabbermouth.
So ... I took a look at the blade on my bandsaw and it appears to be tracking accurately centered on both the top and bottom wheel. Can I assume the wheels are coplaner or at least coplaner enough for all practical purposes. Feel free to be a blabbermouth when replying.
  • 26,012 Total Members
  • JAR Newest Member ·
