Is it worth it to modify HF Dust Collector?
Here’s a video of another guy who switched out his stock Harbor Freight with the Rikon impeller which is the same as the WEN branded impeller I installed. It shows a 1% increase in Amp draw on start up (not hooked up to a cyclone or tool), an average of 9% increase in amps when ready at a steady state connected to a tool (i.e. table saw), approximately 34% increase in static pressure and 15% increase in airflow.
So it looks like the measurements obtained in the video fall inline with what drzaius is saying. I’m not an engineer either, just looking for info to help this make sense to everyone.
https://youtu.be/2NOZTlwHe3A
  • Replies 59
  • Views 52.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Just an FYI for anyone wanting to upgrade their Harbor Freight dust collector fan. You can now also by a fan from Wen Tools. It's the same specs as the Rikon fan but only costs $35 and shipping is fre
  • It's probably drawing more like 100A initially on start up. 10X FLA is a pretty common starting current. Most meters will not react fast enough to show that though.
  • I use a Super dust deputy and vent outside.  I can not see any airborne dust outside, regardless of the tool.  The only downside, for your neighbors,  is that you are also venting a large amount of no
Posted Images
I stand by my assessment. Look at the attachment points. I could be wrong, but I seriously doubt it. My guess is the first impeller was a mistake.
Matt, how big is the intake if you pull the "Y"?  5"? 6"?  I picked up the SDD from Oneida yesterday and the HF DC should come in tomorrow.  Trying to lay out the plumbing and wiring.  It would be nice if the motor can be switched to 220V but at the price i'm guessing no.
Tpt, I thought the same thing at first glance.  All I can tell you is there are numerous videos of this setup running after the swap and I haven't seen one that said anything about bad rotation or poor performance.
5" and from everything I've seen the Harbor Freight dust collector cannot be switched to 220v.
Thanks.
I swear I posted this already but don’t see it. I picked up the Wen fan blade ($35 to my door. Thank you)and the Oneida SDD which has a 6” output to the fan.  Looking for opinions on necking the SDD to 5” or opening the fan intake to 6”. It seems opening it to 6” would give me more psi drop in the cyclone for better separation providing it doesn’t hinder fan performance.
I used this coupling, it fits inside the SDD and 5" hose.
I've read a couple of forums where the stock inlet plate was cut to 6" and something like this 6" air duct collar was used to attach to the SDD inlet with a short piece of 6" DC hose.
https://www.amazon.com/dp/B0058IUUDG/ref=cm_sw_r_cp_apa_fabc_smFbGb9NJY9Z1?_encoding=UTF8&psc=1
I don't think opening the inlet to 6" would cause any performance issues with the bigger impeller.
This guy, at least according to his post, has had the same HF dust collector for 15 years with these modifications and never even closes his blast gates and has great performance.
I plan on doing all of these other mods except the Wynn filter, I'm going to be venting outside.
Also I won't be installing any runs as my shop is my garage which also houses the wife's car, bicycles,etc. so all of my tools are mobilized. I just hook up my DC to each tool as I use it. Can be a pain in the arse I suppose but you learn how to be very organized in your work flow......LOL
Thank you!  This pretty much confirms my plans on this setup. 6" from impeller to waste bucket.  5" main ducting to be split as needed.  Exhaust to outside 5" or 6" depending on price and availability.
@MattCRNA, it sounds like you could benefit from those DC hose quick-connects that Izzy Swan is developing, or something like them.  I find that a short piece of pvc clamped to the hose works well, slipped into a mating pvc coupler adapted to each tool, but Izzy's connectors probably seal better.
