Sandpaper Choices for a Double Drum Sander
Well, I have acquired a new little toy.  Since I really hate sanding, I had plans to buy a Performax sander.  However, while waiting to pull the trigger, I found a used drum sander that looks like it has been used for about 20 hours.  The cost was less than half of the Performax.  It is a 3 HP Double Drum sander by General. It literally looks like new.
I plan to put it use very soon but I would like to get any words of wisdom from you all.
This device has two 5" aluminum drums and it is designed for 2 different grits of sandpaper, with second being finer than first.
While I have lots of question, the first question I have is: what grits of sandpaper would put on the two successive drums?
56f16f4892c1f_GeneralSander.thumb.jpg.73
Nice planer in the background, is that the 24" model? Your planer has the same capacity as your sander! Keeping in mind your planer's width, I think you can turn your drum sander into a bit of a specialist. Unless you are dealing with some tricky grain in a panel glue up, your planer can handle all of your primary flattening tasks. My drum sander functions as a painfully slow planer and intermediate surface prep. In your case, I would most likely use the drum sander as the intermediate surface prep machine. Your planer is going to leave you with some minor tearout and planer marks that grits 100-150 clean up nicely. After 150, it is on to the ROS and your finish of choice. A DS is pretty aggressive, so you can skip grits without too much of an issue. For example, you can do 80 to 120 without a problem, or 120 to 180. You don't have to do the intermediate grits that you normally would use on your hand sander. Finally, you can go up to 180, but that is really when things begin to become more trouble than they are worth. The crap part about drum sanders are the 5" drums. The paper simply doenst have the time or the surface area to dissipate heat before it's back to sanding. When you look at widebelts, there is a considerable amount of travel from the belt sanding to the belt recycling through the drive system and back to contacting the wood again. Lets say the linear distance on a widebelt is 4-6' versus 6-8" on a drum sander. Because of this, it is hard to do 180-220 without some form of pitch build up and burning. Ive done it before, but typically only break it out for super shallow passes on pieces that are 2' long. When you get to pieces that are 4-5' long, you just cant take a shallow enough cut to avoid build up on your 220 paper. This is just my experience though. One thing to pay attention to on your double drum machine is to see if the rear drum can be calibrated to a different height from the front drum. Mine is independent, but some are fixed. If it is fixed, you might be limited in what paper you put on the rear, because you wont be able to control the depth of cut on the back while properly engaging the front.
What do you think will be your primary use?  For flattening panels I would start low and adjust to the upside if the hand sanding took too long after to remove the lines.  Think I would start with 100 on the front and 150 on the back.
The few times I've run 180 on my drum,  I still had to go back to 120 on the ros to clean it up after.
That's my $.02, no refunds,  no returns.
I have this sander and use 100/150. Started with 150/180 but was getting some burning so i switched to 100/150 and have been there for about 5 years now with no issues.
@Pwk5017 thanks for all that wonderful information.  The Rockwell planer is 24" and I have to say that the planer does a really nice job with its 4-knife cutterhead.  My workflow will be to joint-plane-then sand my boards.  I am guessing I have to allow for the sanding with my thickness of the boards.
@Brendon_t My goal with the sander is to reduce my manual sanding workload for the bigger pieces.  I will take your advice as well as others in that I will start with 100 and 150 grits.
@pkinneb I am glad to hear from someone who owns such a tool.  100 / 150 will be my choices.   I am glad that you and others are willing to share your knowledge.  Thanks.
  • 26,009 Total Members
  • Joseph b Newest Member ·
