First jewelry box
Every project needs to have something new that I haven't done before.  This time it is a veneer box with 1/4" square edge banding. I am using bubinga waterfall veneer and probably clear maple on the corners.  Similar construction to Marc's humidor.  If the project goes really well I want to to finish it with a gloss finish and give it my granddaughter  What are some of your favorite high gloss finish systems for this type of project??   Of course if things don't go so well I will use a satin finish and store extra wood screws in it.
General Finishes WB in Gloss looks awesome!  Spray if you can..
I did a couple of high gloss finishes recently. Kev's right! Spray if you can. Maybe a lacquer. Having the initial coats flat will be a great help when the rubbing out starts. Fill the pores if necessary. Here's my process:
Get the thickness you want the finish to be and then spray a few more coats so you have something to rub out. Lightly sand with 320 to 400 between coats. Be sure to get the finish as level as possible as you go. Let the finish cure for weeks.
Start the rub out process with 600 wet/dry paper and lightly soapy water. Use a sanding block on flat surfaces. Stay away from edges until  all the easy parts are done and then carefully hit the edges. Be 100% sure that the surface is level at this stage. It will save you considerable time and heart ache as you go along. Sure you can buff down in some little valleys, but any inconsistencies will be glaringly obvious once you get up to high gloss sheen.
Move up to 800 wet/dry and repeat. Then 1200 wet/dry.
Next go to 2000 abralon pad still using the soapy water. Go to 4000 if you like.
For the final couple of stages switch to a liquid automotive buffing product from Meguiar's or 3M. If the range of coarseness is a scale from 1 to 10 (with 10 being coarse), use a #3 first. They often call it "swirl remover". A cordless drill and a buffing pad is okay for a small project. I would use a separate pad for each different compound so as not to cross-contaminate.
The final buff is with an ultra-fine polish (#1 on the coarseness scale), what they sometimes call "machine glaze".
You could probably eliminate some intermediate steps to speed up the process but this worked for me. Check out youtube videos of guitar finishing for more techniques.
I haven't worked a project with Bubinga. However, I have a small hunk I used to make plugs from. Bubinga has deep and tight grain pockets. Unless you can get the grain filled effectively, high gloss may not look so good and based on your comment above, I think you understand.
-Ace-
