Woodenskye Posted March 31, 2017 Report Posted March 31, 2017 How high do you go when it comes to grit when flattening the back of a plane blade? I am currently at 320 which is the grit of my course diamond stone. I also have about a consistent scratch pattern up to 1/4" from the edge. If it is best to go to my 1000, 4000, 8000 waterstones I'm ok with that. The bevel I plan on doing to 8000. Quote
Popular Post drzaius Posted March 31, 2017 Popular Post Report Posted March 31, 2017 My finest stone is 8000 or 10000 & that's what I go to. The finish on the back is as important as the bevel. 4 Quote
Popular Post BonPacific Posted March 31, 2017 Popular Post Report Posted March 31, 2017 Whatever a strop and green compound is. I see no reason to sharpen the back any less than you're sharpening the bevel. 3 Quote
pkinneb Posted March 31, 2017 Report Posted March 31, 2017 I go to 16K on a Shapton stone but that's because I like the looks of highly polished backs functionally 8K would be plenty. 1 Quote
Woodenskye Posted March 31, 2017 Author Report Posted March 31, 2017 Thanks guys, the jury has spoken, 8000 it is. Quote
Tom King Posted March 31, 2017 Report Posted March 31, 2017 The cutting edge is an intersection of the bevel with the back. The back, at least close to the edge, needs to be finished to a level to match the bevel. That's why the "ruler trick" works. I just do up to about an inch, and am done with it for good. If you raise a burr when sharpening, only use your finest stone to get it off, or you will have to go through a progression to get it back. 2 Quote
Woodenskye Posted March 31, 2017 Author Report Posted March 31, 2017 I ended up going all the way through 8000 on the back and bevel. We will see how it cuts. Quote
