Tool stand
I tried the gray and hated it, ended up painting that project instead. Now I have an almost full can of the stuff taking up space.
  • Replies 60
  • Views 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I added a couple more braces from front to back. They should stiffen it a bit, and they give me a spot to attach the plywood bottom that will keep dust out of the drawer. I attached my tools and took
  • My flip top is based on the Woodsmith (August Home) version and is about 24" x 24" x 28" high.    You want to plan height based on the tool's ability to be flipped as well a
  • Moving right along... I measured for the supports and added them using pocket screws, to speed things up a bit. I also put in the plywood side panels. Those will come into play with adding some storag
Posted Images
Now you tell me. :rolleyes: That's all right, it was a $20 experiment. It actually looks pretty good on the ash, it's just the pine where it came out really unevenly. And then in my attempts to fix it, I think I just made it worse.
Sorry, I was slacking at slacking at work.
Well, I'm not sure I'd do it again, but I think the weathering color is passable. I sanded it back with 120 grit and carefully applied two coats of the weathering stuff. A key part to it turning out seemed to be keeping a wet edge and not letting it pool or drip. It actually looked really good on the ash, but the pine was inconsistent.
I've applied a coat of spray shellac over everything.
After it's had a couple of hours, I'm going to put on two coats of polycrylic on. Then it's just installing all the hardware and the tools.
This is where I was after the coats of polycrylic. It turned out well, except I think the natural pine drawer looks out of place.
I scraped off most of the poly and put on a seal coat of shellac. After that dries, I'll be painting it black. I think that'll go much better, especially with the drawer hardware I picked.
Much better! Now I just need to make it work. I might add a couple of thin plastic washers so it can spin easier.
That looks WAY to fancy for my shop it'd look totaly out of place.
Thanks Drew. It has to compete with the Roubo, right? :D I really only care about functionality, but since I don't do that many builds I might as well have fun with the shop builds. I mounted the tools to it, and for now it's living in the messy and confused corner of my shop that has skis and other sports equipment.
I mounted the barrel bolts and with a little persuading got them to line up top and bottom. It's pretty secure with them in position on both sides. I may still add a steel plate for them to go into, if I find the wood is wearing too much, but that would probably take years. The reality is, the stand is likely only going to flip on average about once a month.
20181203_080637.thumb.jpg.d7940cbae8bfb06521a82322e911bd3d.jpg20181203_080651.thumb.jpg.ca9e62468376fc4391678297e397d548.jpg
I still need to fill the mistaken holes with a dowel. I did run a screw all the way through the steel tube after cutting it to length, but only on one side. This way it won't work loose, but I won't create any problems with binding when it flips. I'm going to pick up my drawer handle today if I have time, then I think that'll wrap this build up.
I think I'm calling this one done. Here's a picture with the drawer handle installed. At some point I may hang tools in the recessed sides, but it's good enough for now.
  • 2 months later...
Are you enjoying your cart? I made one last weekend, roughly based on the Fix This Build That plans. I just need to ease the edges and make a drawer and it'll be done. Maybe some edge banding too. Really glad to have the planer and sander off the ground. I will likely make another for my 10" bandsaw and drill press soon.
Edited by JohnG
Added pic
That's great! Yes, I'm enjoying mine. I can't believe I questioned building it at first. I'm realizing now just how much I avoided using these tools before I had the stand
