bmchan Posted March 3, 2011 Report Posted March 3, 2011 I have owned on of these for 10+/- years and to be honest it has seen very little use. The styrofoam pad to which the discs attach blew apart on me recently and I have not been able to determine if I can just replace that part. Anyone have experience with this before? Quote
Vic Posted March 3, 2011 Report Posted March 3, 2011 I have owned on of these for 10+/- years and to be honest it has seen very little use. The styrofoam pad to which the discs attach blew apart on me recently and I have not been able to determine if I can just replace that part. Anyone have experience with this before? I've replaced both the hook and loop pad and the little belt on both of mine a couple times. I bought mine from a local tool repair shop. Quote
jimmykx250 Posted March 3, 2011 Report Posted March 3, 2011 Porter cable has an excellent online parts ordering service. I have replaced the hook and loop on mine 2 x in the 12 years i have had it as well. That says something about the quality of these little sanders! Quote
Emmrys Posted March 3, 2011 Report Posted March 3, 2011 I have replaced the pad on mine a couple times too. Found one at a local repair shop the first time. Recently I ordered one from Amazon. Quote
JimB1 Posted March 3, 2011 Report Posted March 3, 2011 I haven't had to replace the pad on mine (Model 333) but I have replaced the little o-ring belt which required removing the pad. It's a simple process and Porter Cable parts can be ordered online for pretty reasonable prices. It cost more to get the o-ring shipped then the part cost Here's the link I used, just look up your sander model... http://www.ereplacementparts.com/porter-cable-333-type-random-orbit-palm-sander-parts-c-129_1997_2006.html -Jim Quote
mikepdarr Posted March 3, 2011 Report Posted March 3, 2011 They carry them at Woodcraft and the big stores. Quote
harryangel69 Posted March 3, 2011 Report Posted March 3, 2011 Lowes.com Item #: 269940 It says dewalt in the description because they are stupid. The pic is of the porter cable 5 hole. Dewalts have 8 holes. Quote
Ben H Posted March 3, 2011 Report Posted March 3, 2011 I think HD has them too. Should be about 15 bucks or so. Quote
nateswoodworks Posted March 3, 2011 Report Posted March 3, 2011 I had replaced mine about 6trs ago as well, I wonder if the quality on the new ones are the same or if it has deminished? Nate Quote
jimmykx250 Posted March 3, 2011 Report Posted March 3, 2011 I had replaced mine about 6trs ago as well, I wonder if the quality on the new ones are the same or if it has deminished? Nate I would hold on to the one you have. Quality never seems to go in the a favorable direction. I think it's pretty amazing how long ive had mine now and think of all the sanding ive done with it. It has seen quite a few dusty hours of operation! Not always hooked up to the shop vac. Quote
harryangel69 Posted March 3, 2011 Report Posted March 3, 2011 I have seen those go bad on so many units I just expect it. There is so many things that can effect the foam rubber. Could be sunlight, humidity, or the company that made it. If it was setting outside you expect different wear different than a unit kept in a temperature controlled garage. Just like so many things they are made by the lowest bidder. They order them in massive batches then start the bidding again. The one that came on your unit is most likely the not same one on the shelf. I suspect that this is the difference you find in a festool. Why is the price higher? Quality control. Quote
