Popular Post gee-dub Posted June 2, 2023 Popular Post Report Posted June 2, 2023 This is a bit of a repeat since I posted about the prototype. Looks like the frame will hold a 5 x 7 since holding an 8 x 10 made the frame pretty big. I try not to make gifts so large that they may be hard for the receiver to use . . . DAMHIKT. First off, kudos to Sketch Up for letting me vary the dimensions pretty easily. As I get older I like to have some scribbling on hand to remind me of where I am going. I select the material and pull a blank. The color difference here is due to the fact that I already started milling the blank before I remembered to take pictures. I set up the tablesaw with a 30T rip blade. I rip the blank into pieces closer to the finished sizes of the parts. I use the Mortise Pal to make round-ended 1/4" x 3/4" mortises for some decorative elements. This is best done before the parts are made non-square. I then bandsaw the parts to rough shape. I template route to close-to-final shape. I add some floating tenon joinery. I dry fit the top, bottom and sides, clamp, and route the rabbet for the artwork. This gets me here. I connect the dots to make the slots for the leather hanging straps. I'm going to stop here for today. More tomorrow. 9 Quote
Popular Post gee-dub Posted June 3, 2023 Author Popular Post Report Posted June 3, 2023 I layout the hanger blank and rough cut it at the bandsaw. I wanted to change the scale of the hanger for this smaller frame so I knock out a template. I generally put a center-line on my templates. I use a triangle file to make a little notch on the edge at the center-line. A swipe with a dull red pencil leaves me two lines bordering the notch. This makes it really easy to see when things get dusty. The center-line lets me easily flip parts to route downhill. they can also confirm that things are where they should be if I suspect that something has shifted. I tilt the DP table to drill angled holes for dowels. I learned on the prototype that I wanted like-species dowels. A trip to the scrap bin and a dowel plate take care of that. Add some leather straps and I am ready to put some finish on this. 6 Quote
Popular Post gee-dub Posted June 5, 2023 Author Popular Post Report Posted June 5, 2023 All cowboy'd up. Letting them cure for a day or two before I pack them up for shipping. 8 Quote
Butterfield22 Posted September 9, 2025 Report Posted September 9, 2025 I used hard maple with a clear satin finish for a similar project and really liked the clean, bright look. Chamfered inside edges gave it a more finished, elegant feel. 2 Quote
