TomInNC Posted July 30, 2023 Report Share Posted July 30, 2023 I'm making base cabinets that will sit on concrete in my basement. The floor is unlevel, so I am planning on making a separate ladder-type base that I will screw to the floor/wall, then attach the cabinet to the base. Since the base will be in direct constant contact with concrete, should I be using pressure-treated lumber to construct the base, then trim the base out to match the cabinets? Or is it ok to use plywood for the base as well? I'm primarily concerned about a plywood base warping/twisting because of the ground contact. On the other hand, PT lumber from the home center is likely to have stability issues as well. Quote Link to comment Share on other sites More sharing options...
BillyJack Posted July 30, 2023 Report Share Posted July 30, 2023 No.. you’ll be fine without treated, unless you get moisture during heavy rains. How much out of level? Quote Link to comment Share on other sites More sharing options...
TomInNC Posted July 31, 2023 Author Report Share Posted July 31, 2023 The out-of-level is TBD. Have to cut the LVP out first. Quote Link to comment Share on other sites More sharing options...
BillyJack Posted July 31, 2023 Report Share Posted July 31, 2023 LVP? Quote Link to comment Share on other sites More sharing options...
Tpt life Posted July 31, 2023 Report Share Posted July 31, 2023 Luxury Vinyl Plank- read finished flooring. Quote Link to comment Share on other sites More sharing options...
BillyJack Posted July 31, 2023 Report Share Posted July 31, 2023 Sorry… I thought it was a cabinet question. Quote Link to comment Share on other sites More sharing options...
