Hello
Recently; I have been facing  burn marks when ripping hardwood boards on my table saw. ;) I have checked the blade and it’s sharp; but the issue exist ; especially on longer cuts.
I am thinking the blade might be out of alignment; but I’m not sure if that’s the only cause. I have referred https://www.woodtalkonline.com/forum/10-power-tools/ for help.
Has anyone dealt with similar problems? What’s the best way to check & adjust the blade alignment; and could other factors like feed speed / fence setup contribute to this?:)
Thank you !:)
roreme
+1 to everything Ron said. If you still have your manual, it should cover adjusting the alignment. If not, you can probably find a copy online via a search.
Also, you mention this being a problem with longer cuts - if you pause in feeding the board, say to adjust your push blocks, the wood is more likely to burn then since the it sits in contact for the blade which is probably hot.
And some woods are more prone to burning, e.g. cherry.
Yep, all good stuff so far.  The faces against the table and fence should be milled flat and true.  A 20 to 24 tooth blade for ripping; some folks use a 30 tooth 'glue line rip' for thinner stock with success.  A feather board and outfeed support can help control longer stock. My shop made alignment jig is shown in a couple of posts in this thread
  • Who's Online   4 Members, 0 Anonymous, 36 Guests (See full list)
    32k
    437.5k
    Bob44
    Bob44
